difference between B18a1 vs B18B1
B18A1
Non-VTEC
* Found in:
o 1990-1993 Integra RS/LS/GS (DA)
+ Displacement: 1834 cm³
+ Compression: 9.2:1
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
# 1992-1994: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
+ Transmission: YS1
[B18B1
* Non-VTEC
* Found in:
o 1994-2001 Acura Integra "RS/LS/GS" (DC4/DB7)
+ Displacement: 1834 cc
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
# 140 hp @ 6300 rpm & 121 ft·lbf @ 5200 rpm
+ Transmission: S80
Hope this helps... found from Wikipedia.
Non-VTEC
* Found in:
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
+ Transmission: YS1
[B18B1
* Non-VTEC
* Found in:
+ Bore: 81 mm
+ Stroke: 89 mm
+ Power:
+ Transmission: S80
yup thats the jdm spec. The B18b has a better flowing intake manifold which helps give it the extra hp. Then you also have the CRV head. Which is like a LS head but has the same size valves as Vtec heads.
Allow me to add a couple things about the B18A1. The reason the 92-93 has 10 more HP is due to a slightly higher lift intake cam. Also, the 90-91's came with an S1 trans. The 92-93's came with a YS1 trans. The gearing is identical between the 2, the only difference is the stamping on the outside and the spline shaft diameter is 1 mm larger on the YS1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE »</TD></TR><TR><TD CLASS="quote"><3nonvtec</TD></TR></TABLE>
WTF?....
<3 2kickuintheface
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc-integra111 »</TD></TR><TR><TD CLASS="quote">Allow me to add a couple things about the B18A1. The reason the 92-93 has 10 more HP is due to a slightly higher lift intake cam. Also, the 90-91's came with an S1 trans. The 92-93's came with a YS1 trans. The gearing is identical between the 2, the only difference is the stamping on the outside and the spline shaft diameter is 1 mm larger on the YS1.</TD></TR></TABLE>
EDIT:S80 tranny can be DC2 usdm gsr, b16a2, and LS
Modified by CW_98gsr at 11:18 AM 3/14/2007
WTF?....
<3 2kickuintheface<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mc-integra111 »</TD></TR><TR><TD CLASS="quote">Allow me to add a couple things about the B18A1. The reason the 92-93 has 10 more HP is due to a slightly higher lift intake cam. Also, the 90-91's came with an S1 trans. The 92-93's came with a YS1 trans. The gearing is identical between the 2, the only difference is the stamping on the outside and the spline shaft diameter is 1 mm larger on the YS1.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr »</TD></TR><TR><TD CLASS="quote">
WTF?....
<3 2kickuintheface
lol
WTF?....
<3 2kickuintheface</TD></TR></TABLE>
lol
WTF?....
<3 2kickuintheface
You need professional help.
WTF?....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ritalin.v2 »</TD></TR><TR><TD CLASS="quote">
yup
yup
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">only the crv p8r i think have valves like vtec </TD></TR></TABLE>
it has the highest flowing non-vtec head out there.
yeah
http://www.enginerepacemant.co...c.htm
that site has all the motors !!
B18B = 90-91 GS 1834cc 9.2:1comp. 130 bhp@6000 6,500 redline 121 ft lbs@5000
B18B1 = 92-93 GS 1834cc 9.2:1comp. 140bhp@6300 6,800 redline 121 ft lbs@5200
B18B1 = 94- + LS, 1834cc 9.2:1comp. 142bhp@6300 6,800 redline 127 ft lbs@5200
RS,
or GS
ZC/D16A8/9 = LS, 1595cc 9.6:1comp. 137bhp@6800 7,200 redline 108 ft lbs@5700
or RS
RS,
or GS
or RS
hung_kuen
Nov 20, 2007 07:47 PM
wow i never really heard anyone say that before. you must be playing because it says your from vTec city in cali. and thats where im from
