h22 dizzy question will paypal $10.00 for answer
grabbed this from cb7tuner about h22 swaps:
Internal/External Coil Issues:
If your car came equipped with an internal coil then the JDM H22 distributor will plug right in no problem. However, if your car had external coil then you will have to modify one plug. The plug you will need to modify is the plug that went to the stock coil. There are is a yellow and a yellow/black wire, splice those 2 wires together. The Black/White wire is useless, don’t worry about it. If you dont want to cut the plug off and splice, jam a 30amp fuse into the end of the plug, making the connection between the two wires.
If your car is external coil and you wish to maintain the external coil you will need to open the JDM dizzy, remove the internal coil. Run the wire from the igniter that used to go to the internal coil out of the distributor and plug it into the blank spot on the distributor’s plug. That’s it. Use the 93-95 Prelude Vtec’s Distributor cap and rotor that you can pick-up and your local dealer or auto parts.
cb9sir
Oct 20, 2004 07:34 AM
