Need an opinion on fuel lines...
First off, I have a 1995 Teg which is turbo but im not running the kind of power to require new feed/return lines BUT I do have the problem of corrosion on the existing stock lines under neath the car. Basically, I want to replace them with Steel Braided lines, just wondering if there are any "kits" to be bought or how people connect the lines to there existing (stock) setup ie how do you go from the Braided line back into the stock feed from the tank and to the Filter? Just wondering if anyone had any suggestions? Any help would be appreciated. Thanks
JDMlyfestyle
10
May 18, 2005 11:24 AM
SIReg9
Sep 29, 2003 04:51 AM
