Valve Cover Problem------------------------------->
Old May 23, 2002 | 08:11 PM
SPORT INJECTION's Avatar
Default Valve Cover Problem------------------------------->
I was trying to remove my b16a2 valve cover to strip it with aircraft paint remover. However while removing one acorn nut, it started taking out the threaded post also. I immediately stopped taking it off because I could see the "hexagon" shaped bottom of the post stripping. (I hope you guys understand what im trying to desribe.) How to I get the valve cover off without ruining the post and screwing myself? How do I fix that post? Thanks for any help, something so easy turned into something crappy.
Old May 23, 2002 | 09:03 PM
raene's Avatar
Default Re: Valve Cover Problem-------------------------------> (99MilanoRedSi)
You can buy new ones, they're pretty cheap too. I broke one once tightening that plastic spark plug wire onto the valvecover. Scared the poo out of me
Old May 23, 2002 | 10:07 PM
Roger's Avatar
Yeah, just buy them on the interent at:
http://www.hondaautomotiveparts.com/
http://www.acuraautomotiveparts.net/...p/mws/home.htm
Both of these website are awsome !! The honda site is hella fast with the ordering process. I purchased something from them monday and I got it today ( Thursday ). Hope this help.
Old May 24, 2002 | 04:33 AM
Default Re: Valve Cover Problem-------------------------------> (Roger)
How do you get them back in so it stays?
Old May 24, 2002 | 04:53 AM
I think I answered my own question, so it just screws in? Thanks alot that site is great!
Old May 24, 2002 | 12:21 PM
HaUTSaauce's Avatar
New User
i had to buy one 2 days ago i thikn i payed 5.70 for one
Old May 24, 2002 | 02:45 PM
raene's Avatar
Yup, just use a deep socket. The guys at Honda said that the intake and exhaust side bolts are different, so keep that in mind. They had one in stock but had to order the other one (one I needed). Took about a day, no big deal.
Old May 24, 2002 | 06:49 PM
HOOKUPS-PRO-CRX's Avatar
Default Re: Valve Cover Problem-------------------------------> (raene)
be careful when replacing that bolt if its a 12mm one (onthe inside of the valve cover then it needs to be torqued to 16ft lbs, if its one of the studs on the outside then it is less critical but the torque is 7.2 ft lbs
Old May 25, 2002 | 09:07 AM
Kataku2K3's Avatar
Default Re: Valve Cover Problem-------------------------------> (HOOKUPS-PRO-CRX)
Yea those bitches suck when they break. But oh well just replace it, that's what my friend had to do on his GSR.
Old May 25, 2002 | 09:36 AM
redteg1's Avatar
Default Re: Valve Cover Problem-------------------------------> (JDMspecEG6)
haha how did u do that? ur valve cover was already stripped?! anyway....i bought mines from the dealership and they do not come cheap.
SteezyEG
12
Oct 28, 2012 02:23 PM
Crazy_SI_T
Appearance Build Threads
Apr 19, 2010 03:43 PM
RedneckRicer
Nov 13, 2008 12:29 PM
96CXhatch
Aug 28, 2005 06:57 PM
Dirk McGirk
Oct 5, 2003 05:56 PM
