cel code 1 and 9
first let me give you the setup
95 cx
d15b8
chipped p28 with crome
LC-1 with yellow wire spliced into d14
also using the lc-1 as the a replacement for the the stock o2
the problem is my car will drive fine for about 15 mins then it will throw a cell and start stuttering and shutting off
so i checked the codes and im throwing code 1 and code 9
1 is the 02 and 9 i believe is the cyp on the dizzy
im going to try wirign the dissy striaght to the ecu to see if it fixes that problem
but my main concern is the o2
i used the the write up on here to install my lc-1 and double checked the wiring.
the only thing i can think of is do i need to program the lc-1 narrow band output in the programer becasue i only did the wideband tab
95 cx
d15b8
singleslammer
Jul 14, 2008 09:43 AM
srv3fender
Mar 2, 2005 10:05 PM
