d16y7
Old Mar 19, 2007 | 05:41 PM
ekblack9's Avatar
Default d16y7
okay so i just spent about 1000 dollars to fix my car....my tranny was fucked, my clutch was done and my bearing was done so the mechanic replaced everythin and i was actually saving up for an engine swap but since i spent it on fixing it cuz i need this car everyday its my everyday car. well what my question is can i upgrade my engine which is a d16y7 97 civic hatch and throw turbo on it?
i tried searching it but nothing came up...i was wondering how much a turbo would cost for this engine. and any good places anyone know of where i would be able to get one
Old Mar 19, 2007 | 05:52 PM
ifIexplode's Avatar
I would.
Swap manifold from a y8
You can peice together a turbo kit for about 1500 dollars.
Get a tune
Run 7-9 pounds daily
try the honda tech market place
Old Mar 19, 2007 | 05:56 PM
92hatch_cx-t's Avatar
Default Re: (ifIexplode)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">I would.
Get a tune
try the honda tech market place</TD></TR></TABLE>
X2 GL
Old Mar 19, 2007 | 06:53 PM
cambopheonix56's Avatar
Default Re: (sohc dis)
7-9lbs daily? What? You don't know what turbo (makes a huge difference), condition of motor, ect. I sway swap a y8 manifold and turbo it. Doesn't matter what psi as long as the block doesnt exceed around 225whp.
PSI means nothing. The block can only handle so much power.
Old Mar 19, 2007 | 06:54 PM
ekblack9's Avatar
sounds good... how much hp u guys think i can get out of it?
Old Mar 19, 2007 | 07:04 PM
ifIexplode's Avatar
I was only Generally Speaking.
Old Mar 19, 2007 | 08:36 PM
ekblack9's Avatar
would i be able to put a y8 manifold right now...and would it do a difference right now, all i got under my hood is a cold air intake and exhaust with 2.25 piping
Old Mar 19, 2007 | 09:02 PM
ekblack9's Avatar
any other opinions or tips
Old Mar 20, 2007 | 01:52 PM
walsh22's Avatar
Default Re: (ekblack9)
MIni me swap to y8 head and intake manifold, get the right ecu and go vtec and then pieace tigether a turbo kit
Old Mar 20, 2007 | 02:00 PM
a milano fred's Avatar
check out http://www.d-series.org, plenty of good information for setting up your turbo d. swapping a y8 head would help but you could still get a good amount of power with your y7 if you tune it correctly
Old Mar 20, 2007 | 03:49 PM
4theluvofhonda's Avatar
Default Re: (a milano fred)
Make sure before you just slap on the turbo kit that you replace everything, i.e. timing belt, fuel filter.....so on and so fourth. do all of your maintainence and make sure your car is running 100% perfect. Then you want to get most likely a T2 turbo. The single cams wouldn't be able to handle a T4 turbo, and I'm not quite sure about the T3. But just make sure to do your research and you get your engine in perfect condition before you start doing bolt ons.
Old Mar 20, 2007 | 03:50 PM
Default Re: (4theluvofhonda)
another good website is... http://www.turbod16.com
Old Mar 20, 2007 | 03:54 PM
EX-T's Avatar
I've got a buddy running with a d16y7 and his setup is as follows...
STR manifold
t3/t04b .48 hot side .63 compressor side
2.5'' charge piping
240cc d16y8 injectors
walbro 255lph fuel pump
dsm blow off valve
made 208fwhp/207fwtq with stock internals at 11 psi!
Case in point....BOOST THE Y7!!!!
Old Mar 20, 2007 | 08:08 PM
ekblack9's Avatar
sweet thanks for all the feedback guys
541delSol
10
Feb 23, 2023 10:06 PM
Tagman87
18
Jun 12, 2012 07:44 AM
yackkie_k
Mar 28, 2007 01:14 PM
BrianDelSol
13
May 14, 2004 06:39 AM
devonic
Jul 21, 2003 06:57 AM
