Help with fuse blowing after B16 swap.
Old May 23, 2002 | 07:33 PM
NC-B17A's Avatar
Default Help with fuse blowing after B16 swap.
A friend of mine just swaped in a B16A1 into his 92 DX Civic hatch. The car will crank and idle fine,but the charge light stays on while the cars is runing.He had the alternator rebuilt today and that was not the problem. When you get into hard throttle the alternator solenoid fuse in the fuse box blows.It kills the ecu,spark,& fuel pump. Have any of you run into this problem. The car will drive at light throttle without blowing the fuse. TIA
OldSchoolCrxSiR's Avatar
Default Re: Help with fuse blowing after B16 swap. (NC-B17A)
check the ecu! or reset it!
Old May 23, 2002 | 10:21 PM
vsual's Avatar
A good percentage of electrical problems like this can be traced to bad grounds. Make sure all the groundings are grounded good.
Did he or you by any chance removed the interior dashboard??
[Modified by vsual, 11:22 PM 5/23/2002]
Old May 24, 2002 | 08:11 AM
NC-B17A's Avatar
Default Re: Help with fuse blowing after B16 swap. (vsual)
The dash was not removed
Old May 24, 2002 | 08:26 AM
vsual's Avatar
check your groundings.
leem23vtec
Feb 10, 2022 09:35 AM
951dc5
Dec 19, 2008 11:36 PM
revhigh96
Jun 21, 2003 03:16 PM
B16ED4G
Jun 3, 2002 06:19 AM
NC-B17A
May 23, 2002 08:32 AM
