Bazooka sub with any 10" sub
Old Mar 19, 2007 | 04:20 PM
lsvtek's Avatar
Default Bazooka sub with any 10" sub
Hi, I was wondering if a 10" kicker sub will fit the bazooka tube, then run wires to a seperate amp. Recently it poped twice and I want to get a better sub for it and better amp, same tube but diffrent sub. thanks
Old Mar 19, 2007 | 06:08 PM
skingfreak's Avatar
Default Re: Bazooka sub with any 10" sub (LSintegra4)
if the tube has a 10" diamator,and the sub you want has a simaler diamtor it will fit. do a little reasearch in to the new sub, and you will find the mounting diamtor, which will tell you if it will fit or not
As a side not: if the tube is ported chances are it will not sound great since the new sub will have difernt paramators, which means it requires a different box. you would be better of making a stealth box.
But to everyone their own...
Old Mar 20, 2007 | 08:39 AM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSintegra4 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I was wondering if a 10" kicker sub will fit the bazooka tube, then run wires to a seperate amp. Recently it poped twice and I want to get a better sub for it and better amp, same tube but diffrent sub. thanks</TD></TR></TABLE>
you could easily find another sub that might fit in there.....however....the new speaker might not "like" it's new enclosure. you might need to build a specific enclosure for the new sub in order for it to sound good. bazooka tubes tend to start farting on you after a certain volume level. bazooka tubes are meant mostly for a little bit of bass in a tight mounting area. if you are looking for boom....get a real enclosure.
1.8t
Aug 18, 2004 02:22 PM
1SIKCRX
Audio / Security / Video
Mar 12, 2004 08:51 PM
97Civic-R
13
Jun 15, 2003 05:10 AM
