Problem engine surging lights surging miles being put on while idling???
Old Mar 19, 2007 | 04:04 PM
ITR.#1446's Avatar
Default Problem engine surging lights surging miles being put on while idling???
My friend is having problems with his type r. Today he starting over heating because his coolant line going to or from the heater core were leaking. Now when the car is started the mph bounce around, the motor is surging ( probally cuz coolant needs to be bled), the lights surge and the wierdest thing is the odometer is putting miles on while it is idling. What is the problem with his car i cannot figure it out???
speed sensor is fine check with a new one
Old Mar 19, 2007 | 04:24 PM
ITR.#1446's Avatar
Default Re: Problem engine surging lights surging miles being put on while idling??? (ITR.#1446)
just got a scanner and codes were p1298 electrical load detector high input and p0141 o2 heater circuit malfunction what does the p1298 mean?
Old Mar 19, 2007 | 06:03 PM
MightyMouseTech's Avatar
Sounds like the voltage regulator in the alternator is toast and the alternator is putting out higher than normal voltage.
Old Mar 19, 2007 | 07:09 PM
ITR.#1446's Avatar
Default Re: Problem engine surging lights surging miles being put on while idling??? (MightyMouseTech)
do you think that is the problem? i did the check in the manual with the 3 pin connector for the ELD and everything was good.
the idle and all the problems start only when the car is revved after its been running it keeps popping the number 15 fuse.
the funny thing is the car put 10 miles on just sitting in my garage lol
Old Mar 20, 2007 | 09:03 AM
ITR.#1446's Avatar
is this an alternator problem?
Old Mar 20, 2007 | 09:16 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR.#1446 &raquo;</TD></TR><TR><TD CLASS="quote">just got a scanner and codes were p1298 electrical load detector high input and p0141 o2 heater circuit malfunction what does the p1298 mean?</TD></TR></TABLE>
Sounds like the Primary or Secondary O2 sensor wires are shorting out (particularly the fat white wire).
Old Mar 20, 2007 | 09:31 AM
walker111's Avatar
Default Re: Problem engine surging lights surging miles being put on while idling??? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like the Primary or Secondary O2 sensor wires are shorting out (particularly the fat white wire).</TD></TR></TABLE>
I would say you def have a short somewhere...
Old Mar 20, 2007 | 10:04 AM
vtec.dc2's Avatar
sound like you got coolant onto vss plug.. clean it out and your needle will stop jumping all over the place
Old Mar 21, 2007 | 01:24 PM
ITR.#1446's Avatar
Default Re: Problem engine surging lights surging miles being put on while idling??? (vtec.dc2)
no i put in another its not that...its popping the 7.5 alternator fuse but i did the ELD tests and everything was within spec
Old Mar 21, 2007 | 01:38 PM
itr1244's Avatar
let me know how it goes.. cuz i do have similar problem
Old Mar 21, 2007 | 01:42 PM
ITR.#1446's Avatar
Default Re: Problem engine surging lights surging miles being put on while idling??? (itr1244)
its beat he is getting a new alternator to see if thats the problem..... the second i put in a new fuse and start it the fuse pops
Old Mar 23, 2007 | 05:57 PM
ITR.#1446's Avatar
it was the secondary o2 shorting out on the exhaust cuz it was melted
Old Mar 23, 2007 | 06:13 PM
itr1244's Avatar
at cold start. my car was running very rich. i leaned it out a little bit at 1000-2000 rpm range few % and the problem's mostly gone.
Soup Slayer
Sep 11, 2013 01:36 PM
huge230
Aug 20, 2008 01:36 PM
ixsan25
May 11, 2008 12:04 PM
xxh3iiraz0rxx
Sep 23, 2007 05:31 PM
