O2 sensor question
Old Mar 19, 2007 | 03:57 PM
boosted97civic's Avatar
Default O2 sensor question
i have a 1997 HX civic that came with a d16y5 with vtec e i just put a GSR in it, i bought the conversion harness for OBD2 to OBD1 for the ecu, my question is will the front o2 sensor work with the ecu its a 5 wire one or do i use the back one and do i have to try to figure out how to make a 4 wire o2 sensor work?? Thanks a bunch!!!
Old Mar 19, 2007 | 04:32 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: O2 sensor question (boosted97civic)
I'm assuming you're using an OBD1 P72? You will need to convert your engine harness from 5-wire to 4-wire or use a "VTEC" harness instead otherwise you will throw a code. Also if you're converting to OBD1, you don't need 2 O2 sensors anymore. Only 1 required.
400WHPITR
Jan 29, 2007 10:38 AM
russianswty
Dec 29, 2006 04:30 PM
TH33G4MON3
11
Oct 22, 2005 07:05 PM
PhatwhipsJDMkits
10
Nov 11, 2004 06:38 AM
qqqq
Apr 8, 2003 07:53 PM
