'91 B18A Block, '97 B20B head
Old May 23, 2002 | 06:32 PM
Quik Chris's Avatar
Default '91 B18A Block, '97 B20B head
Alright guys. Here's a question. I'm going to be putting my old B18A block w/ VTEC oil and water pumps w/ a '97 B20B heahd into a '97 Civic HB. Correct me if I'm wrong on these parts which I need-- the head doesn't have a distributor, Intake manifold, or valve cover.
LS head gasket (or CR-V?)
LS Axles
LS ECU (OBD-II)
LS OBD-II/B16A2/Type R '97 Intake manifold and T-body
B20 Valve cover (can I use an LS?)
Old May 24, 2002 | 10:05 PM
Quik Chris's Avatar
Default Re: '91 B18A Block, '97 B20B head (Midori Shinkansen)
Anyone? Also, B20 or B18B distributor?
Old May 24, 2002 | 11:29 PM
Eddoes's Avatar
I think u have that the wrong way around. Should be B20B block with the B18A head.
Old May 25, 2002 | 08:53 AM
Kataku2K3's Avatar
Default Re: '91 B18A Block, '97 B20B head (94hondahybrid)
Yea you'll need the LS manifold unless you want to cut a hole in ur hood where the CRV one can pop through. Otherwise you should be set.
Old May 25, 2002 | 01:27 PM
Quik Chris's Avatar
Default Re: '91 B18A Block, '97 B20B head (JDMspecEG6)
haha, I should cut a hole in the hood... hahaha. Cool, looks like a plan. Thanks guys.
johnnyham89
Honda CR-V & Element
Jun 17, 2011 02:52 PM
existanzcivicb20
Dec 15, 2009 01:05 PM
eRACING
Sep 18, 2003 03:16 PM
TEGPOWER44
Dec 8, 2002 06:05 AM
