Cooling Issues
Old Mar 18, 2007 | 08:23 PM
fe519's Avatar
Default Cooling Issues
Hey everyone, I have a problem but dont know what other options I have. My radiator blew up 3 days ago and I replaced it. Now, when I drive the car for about 10 minutes, the temperature starts to move up to hot. The weird thing is that when I turn the heater to max hot, the temp drops back down to normal. Today, I went and replaced the thermostat and the radiator caps and it still does it. I opened the radiator cap with the car on to bleed the air out already and nothing seems to be working. The funny thing is that after I drove the car, I opened the raditor cap slowly(yeah, i know i should do that) and there is ALOT (much much more than normal) of pressure inside the system. What would cause this? Also, anyone have any ideas what else I can do? Thanks for reading.
Old Mar 18, 2007 | 08:28 PM
GraphiteMW's Avatar
Default Re: Cooling Issues (fe519)
Thats not wierd its normal, when you run your heater it actually cools down your car instead. Not sure whats your problem though. Any white smoke coming out from your exhuast when you step on it?
Old Mar 18, 2007 | 08:37 PM
Hawkze_2.3's Avatar
Bleed it more from the bleeder screw on the thermostat housing, not the rad cap.
Your oil is not starting to look milky or anything is it?
Old Mar 18, 2007 | 08:41 PM
Rosko's Avatar
Default Re: Cooling Issues (Hawkze_2.3)
any reason the radiator blew? check your oil like hawk said, might have a blown hg.
Old Mar 18, 2007 | 08:43 PM
TruNinja619's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Bleed it more from the bleeder screw on the thermostat housing, not the rad cap.
I would let the car warm up to normal operating temperature.. and even wait till the lower radiator hose is at least warm.. then crack open the bleeder screw and watch a steady stream of coolant coming out from the screw and close it...
if you're still having overheating issues.. I would do a pressure check on the radiator cap if you havn't replaced that yet...
I3ooS710
69
Jun 17, 2006 08:10 AM
Dc2 FrEaK
Feb 26, 2006 02:05 PM
NastyGsr94
Dec 2, 2003 07:02 PM
NastyGsr94
Dec 1, 2003 07:56 PM
celmar1
Jan 9, 2003 06:54 PM
