97 ITR cams w/ 99SI b16 stock valvetrain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT »</TD></TR><TR><TD CLASS="quote">I know 1st gens it's a no no, but is it true the 99 si b16s have dual valvesprings which makes it capable to run itr cams?</TD></TR></TABLE>
If you plan to leave the rev limiter stock, you will be fine. If you are increasing the rev limiter then you SHOULD get at least ITR springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">why not just get some ITR intake springs and be safe? stock probably be fine if your not reving over 8k</TD></TR></TABLE> do want to go through the troubles of paying for valvetrain, clean and surface head, new headgasket, and head studs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by faSHOwidIT »</TD></TR><TR><TD CLASS="quote"> do want to go through the troubles of paying for valvetrain, clean and surface head, new headgasket, and head studs.</TD></TR></TABLE>
I didn't even take out the head when i replaced the valve train with the ITR. Actually, i didn't even change the valves, only the valve springs, and retainers. Theres a tool you can use with out having to take the head off, trying searching for it. Reving pass 8000RPM with ITR cams will give you better HP and Tq gains.
the exhaust side is most vulnerable since there are only single springs. I reccomend getting some portflow inners x16 if thats all the cam you are
going to run. $80 for a set last I looked. the tool to put them in while on the
car will run you about the same. be sure you have some extra keepers!
sloweredcivic
Apr 30, 2005 08:37 AM
jdm.ej
May 4, 2004 05:17 AM
