front bumper cover removal (4g hatch)
Old May 23, 2002 | 04:57 PM
Hcivic88's Avatar
Default front bumper cover removal (4g hatch)
im quite sure its the bumper cover that i wanna remove, its the plastic piece on the bumper, so im figuring thats called a bumper cover.
so anyways, does anybody know what screws/bolts are where to remove the cover?
thanx a lot for the help
Old May 23, 2002 | 05:42 PM
Hcivic88's Avatar
Default Re: front bumper cover removal (Hcivic88)
somebody must know how to do it??? someon out there's gotta have a helms, i should really pick me up one of them
but for now can someone tell me? please
Old May 23, 2002 | 06:28 PM
KiddieRydesCRX's Avatar
There are 3 phillips head screws between the headlights. Good luck getting them out. They're a . There are 2 screws or clips on the wheel opening part of the bumper cover, and a few bolts in the bottom grille part of the cover (10mm). After they are all out, slide the cover forward and you're done! Those 3 phillips heads between the headlights will probably strip out on you. I had to take a cut-off tool, cut into the head of the screw and use a jumbo straight head screw driver to get them out.
Old May 23, 2002 | 06:32 PM
Hcivic88's Avatar
Default Re: front bumper cover removal (KiddieRydesCRX)
alright, thanx a lot for the help, i found 2 philips screws by the front wheel wells, just gotta look around for the rest, and those headlight ones will be fun
thanx again
Old May 25, 2002 | 11:03 PM
Gaijin's Avatar
Dude. KiddieRydes is a real patient guy. If you actually read threads you would have had your answer before you wrote your first word. Of course, if you actually looked at your car periodically, it's really not that hard to figure out, either.
dudefella
Jul 16, 2006 06:10 PM
deathman68
Apr 2, 2006 02:29 PM
Layziebtnh055
May 14, 2004 04:37 AM
Gofimoid
Apr 29, 2004 12:58 PM
