MAP Check Valves
Old Mar 18, 2007 | 05:46 PM
h22sedan's Avatar
Default MAP Check Valves
So I was out looking for the check valves everyone puts in their MAP sensor vacuum line. I know the commonly used is a T valve but this is all I could find...
It allows air to pass through one way, but not the other. I hooked it up to a vacuum line to my boost gauge, I'm going to test it tomorrow with a vacuum pump, I sucked on the line and managed to pull it down to 5 vacuum, and when blowing on it never hit positive pressure.
Does anyone think this type of check valve will work??
Old Mar 18, 2007 | 06:09 PM
HamiltonRex's Avatar
Default Re: MAP Check Valves (h22sedan)
i didnt use a check valve on my map line?
Obd1 with stock map.. I was only running around 7psi though..
Old Mar 18, 2007 | 06:13 PM
h22sedan's Avatar
Default Re: MAP Check Valves (HamiltonRex)
I heard that anything above 2psi and the ECU would throw a CEL for the MAP sensor. I only plan on running 8psi once fully tuned, right now around 5 psi AFC tuned.
The kit isn't on the car yet, just trying to make all the nesscary steps to get it all in the car and functional in one day.
Old Mar 18, 2007 | 06:14 PM
Ludman95's Avatar
Ive seen people use the tetra one way valves before and it work with no problems, try a pet store in the fish department.
Old Mar 18, 2007 | 06:15 PM
h22sedan's Avatar
Default Re: MAP Check Valves (Ludman95)
But the valve I have in the picture won't work?
Old Mar 18, 2007 | 06:16 PM
Tippyman's Avatar
Im a manager at a pet store, and we have those.
Old Mar 18, 2007 | 06:21 PM
Ludman95's Avatar
Default Re: MAP Check Valves (Tippyman)
Im not sure about those working or not, i know the tetra ones work though, you just put like three of them inline before the map and they will bleed off the boost before the map see's it
Old Mar 18, 2007 | 06:22 PM
h22sedan's Avatar
Is the valve you're speaking of a T shape or just an inline like I have in the picture?
Also, can anyone enlighten me as to how the T valve should be installed? like direction of flow... a picture or diagram would be great.
Old Mar 18, 2007 | 06:51 PM
h22sedan's Avatar
bump
Old Mar 18, 2007 | 07:04 PM
ALL_MOTOR_FKR's Avatar
I used them same one's you have a pic of on a d16 at 8 psi and they worked for me
Old Mar 18, 2007 | 07:35 PM
bigbadboy's Avatar
the one in the pic you have will work. but you'll prob need more than one
Old Mar 18, 2007 | 08:33 PM
22psicrx's Avatar
i think you need 3 in line
Old Mar 18, 2007 | 08:58 PM
bigbadboy's Avatar
my friends have always used 4-5 in line before the map sensor
Old Mar 19, 2007 | 03:28 AM
h22sedan's Avatar
Default Re: (bigbadboy)
Right now I've only got 3 of them, I pretty much cleaned Wal-mart out.
Old Mar 20, 2007 | 12:37 PM
Default Re: (h22sedan)
i didnt relize you werent using proper EMS.
Old Mar 20, 2007 | 05:29 PM
welfarepc's Avatar
those check valves will work as long as they let air ESCAPE, put dont allow anything IN. So you can blow out air no problem, but can not suck any air in. If it does that, you are good as gold. Run 3 to make sure it vents quick enough.
Dan
Old Apr 3, 2007 | 08:35 AM
JST1CAM's Avatar
Default Re: (welfarepc)
How do you hook up the check valves to the TB and MAP sensor
Old Apr 3, 2007 | 08:49 AM
efloved16t's Avatar
Default Re: (JST1CAM)
please dont use those. get a affordable ems and a 3bar map. with much better results and safer.
Old Apr 3, 2007 | 09:30 AM
JST1CAM's Avatar
Default Re: (efloved16t)
Its just for the time being while i save for a EMS
shaggyeg6si
May 15, 2008 07:48 AM
88crxhfb16
Apr 29, 2005 07:30 AM
pelotudo
Aug 23, 2002 09:09 PM
technine
Aug 8, 2002 02:52 AM
