which is a better vaccum source for twm itb's?
Old Mar 18, 2007 | 04:56 PM
H-powerd's Avatar
Default which is a better vaccum source for twm itb's?
Hey everyone just wondering what you guys think is a good vaccum source for my h22 with twm itb's. I have a golden eagle vac log and was wondering should I use the nipples on the itb's now that are above the fuel injectors or should I tap new nipples below the injectors? And run them all too the itb's? With each one taping into each other for the map source? Anyone with any advice would be great thanks.(note I currently have no vac lines going to the itbs to the vacc log, and the brake booster tead into the vacc log and in the 1# runner.)
Old Mar 18, 2007 | 07:09 PM
high_revs's Avatar
bump for an anwser
Old Mar 18, 2007 | 07:46 PM
Rosko's Avatar
Default Re: (h2b_eg8)
bump for an answer too. I often wondered myself if certain places in the runner were better for vaccum than others, I noticed that most stock honda tb's pull vacuum from right behind the throttle shaft.
Old Mar 18, 2007 | 07:49 PM
GAME OVER 2007's Avatar
Dyson
Old Mar 19, 2007 | 01:36 PM
H-powerd's Avatar
Default Re: (Integra n Civic)
anyone with itb's that reads this please post were your vaccum lines go to your vaccum box. thanks
Old Mar 19, 2007 | 03:02 PM
doood's Avatar
been there done that
Default Re: which is a better vaccum source for twm itb's? (H-powerd)
do like this guy: https://honda-tech.com/zerothread/1924658
Old Mar 19, 2007 | 07:28 PM
j spec's Avatar
Default Re: which is a better vaccum source for twm itb's? (doood)
Link above is how my setup is ran, works great. Its not necessary to place it closer to the head on TWMs but, the closer the line is, the more vacuum is pulled. Unless you are going to be tuning off of a map reading, in which case it may benefit you slightly.
good luck
-roma
allmotaeg6
Oct 29, 2009 12:05 PM
JBBNJ609
Apr 8, 2005 01:36 PM
Guam_CiviC619
Oct 8, 2004 11:19 AM
user 996328629
Apr 23, 2004 05:50 PM
JDMlyfestyle
Feb 19, 2004 04:45 PM
