help a NC
I tryed to crank my b16 today for the first time and it didnt crank...there is a wierd noise comming from under the steering wheel at the fuse box...I think....thats just when I touch the positive to the battery it starts that noise....also my battery is relocated to the back
Some one from NC or any where can you please come help me get it started....will lend some money if I have to
heres some pics
the rims going on it when I get it running
heres some pics
ok i found out what the noise was...fixed that but I got it to crank today but I have an exhaust leak between the cat and the header...also some of the vaccum lines are messed up and I am throwing code 4 ckp sensor...how do I fix that and I am also idling real high
check the PCV valve on your intake manifold...mine was cracked and the cars idle would sky rocket...other then that your idle could be caused by the vacumm lines being messed up or a leak somewhere
good luck
good luck
c-townekhatch
Mar 13, 2007 03:15 PM
.kyle
Jul 31, 2006 01:34 PM
Mud666
Nov 3, 2005 09:19 PM
