Help... CEL
Old May 23, 2002 | 04:15 PM
metal-x's Avatar
Default Help... CEL
I was parked for a while when I started car back to leave I got a CEL, I then shut down the car popped the hood to see if I can see any visual problems, nothing no leaks or loose belts,hoses, etc.. I then restarted the car and drove around for 20 min and no CEL now what the hell could it be?
Old May 23, 2002 | 05:23 PM
EVOTHIS's Avatar
Default Re: Help... CEL (metal-x)
CEL's are emmisions related. if your gas cap is loose it can throw a CEL too.
I wouldn't sweat it too much unless you start seeing it again. you can drive just fine with a CEL, but I would get the dealership to check it out for you, what year is your teg? if it fall within a certain year the dealership can warranty it for you. there is an extended emissions warranty on some acura models to 150,000 miles.
Old May 23, 2002 | 06:27 PM
Spec R's Avatar
Default Re: Help... CEL (b18c ya)
next time it goes off, find out what it is, before it goes away...could be anything
Old May 23, 2002 | 07:00 PM
metal-x's Avatar
Its a 95 Gsr so I have no warranty I just got back from an hour drive on the road and highway I took it to 160km/h and everything seemed normal
does the ecu trick work on integras?
Old May 24, 2002 | 12:52 AM
quickspoolin's Avatar
Some CEL codes are intermittent. I suggest that if it comes back check the code, if not it's probably just an intermittent failure.
harlen
Feb 19, 2008 05:31 PM
TEGME
Jan 27, 2003 03:04 PM
vti-R
Oct 23, 2001 06:18 PM
