Stripped bolt thread on crankshaft! What to do?
Old Mar 18, 2007 | 10:46 AM
NSTY Z33's Avatar
Default Stripped bolt thread on crankshaft! What to do?
I decided to post this here since most of metal/machining is dealt with here.
A bolt thread hole on my crackshaft stripped The bolt also is stripped. Can a normal machine shop fix this? What will it cost around if it's fixable?
Old Mar 18, 2007 | 03:19 PM
Sims's Avatar
Default Re: Stripped bolt thread on crankshaft! What to do? (NSTY Z33)
is this a flywheel bolt or what?
Old Mar 18, 2007 | 06:28 PM
NSTY Z33's Avatar
It's the thread for the flywheel bolt on the crankshaft.
The bolt itself is stripped too.
Old Mar 18, 2007 | 06:44 PM
wantasol's Avatar
Default Re: (NSTY Z33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NSTY Z33 &raquo;</TD></TR><TR><TD CLASS="quote">It's the thread for the flywheel bolt on the crankshaft.
The bolt itself is stripped too. </TD></TR></TABLE>
The bolt is not the problem. You can get a new one of those. The threads in the bolt hole is your issue.
Old Mar 18, 2007 | 06:54 PM
Howitt's Avatar
Default Re: (wantasol)
if there is still meat there clean up the thread with tap or helicoil it, or weld it shut and drill and tap
Old Mar 18, 2007 | 09:10 PM
NSTY Z33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantasol &raquo;</TD></TR><TR><TD CLASS="quote">
The bolt is not the problem. You can get a new one of those. The threads in the bolt hole is your issue.</TD></TR></TABLE>
oh well thanks for reminding me of the problem..
I'm looking for advice and answers to my question!
NSTY Z33's Avatar
Default Re: (Howitt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">if there is still meat there clean up the thread with tap or helicoil it, or weld it shut and drill and tap</TD></TR></TABLE>
I don't want to take the chance of doing in myself. There is meat on it.
My question is can a machine shop salvage it.
Old Mar 18, 2007 | 09:55 PM
NJcoupe's Avatar
A machine shop can do almost anything.
Old Mar 19, 2007 | 05:41 AM
JDcompman's Avatar
It would probably be easiest to just take it to a machine shop and ask them. Any good machine shop should be able to tell you if they will be able to fix it for you, just by looking at the damaged hole. It's always easier to answer questions like this by actually seeing the problem. I'm sure if you called a machine shop they would tell you the same thing..."well we will probably need to see the damaged hole to be able to give you a definite answer."
poolpool8
Apr 1, 2017 09:12 PM
sawedoffcoupe
Aug 16, 2008 05:12 AM
xkhalil333x
Dec 24, 2003 12:49 PM
al3e
Dec 14, 2003 04:07 PM
88 rex
Jul 24, 2003 02:18 PM
