Ever been a case of sub frame tear using bsq or beaks kit?
Old May 23, 2002 | 04:00 PM
b18bfreak's Avatar
Default Ever been a case of sub frame tear using bsq or beaks kit?
Just wondering..
Any cases of ripped sub frame with these kits?
Old May 23, 2002 | 05:05 PM
HondaJon's Avatar
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (b18bfreak)
None to date that anyone one Honda-Tech has heard of I believe.
When installed properly, the BSQ and Beaks kit provide more than enough cross member support for the bar to prevent any subframe tear out.
I just put my ITR bar on yesterday with the BSQ kit, and it works great.
Jon
Old May 23, 2002 | 05:14 PM
neo1z's Avatar
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (HondaJon)
never heard of any issues....at least with the bsq kit. only thing ive heard is that it is the best "bang for the buck" suspension mod...maybe the best in general (competing with AEM CAI)
Old May 23, 2002 | 06:41 PM
BlowOff's Avatar
New User
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (neo1z)
Been running mine for almost 2 years now with the BSQ kit...NOT A PROBLEM...knock on wood
It does wonders...the only other suspension mod I made that would compare before and after rides is my Quaife! I love the R sway bar.
Old May 23, 2002 | 07:00 PM
JCushing's Avatar
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (BlowOff)
you can use the bsq kit with any sway bar setup right. i have the skunk2
Old May 23, 2002 | 09:01 PM
JL 74's Avatar
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (JCushing)
This I don't know. Just wait till BSQ (Bret) informs you. He is and has gives good customer support and advice.
Old May 23, 2002 | 10:33 PM
NWPNOMORE's Avatar
Banned
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (jl74)
bsq kit worked for me
Old May 23, 2002 | 11:01 PM
ARACER25's Avatar
I have the beaks kit and I like it better only because it reinforces both sides of the subfram. It is a little more but this is the one I wanted. He help and customer support was outstanding!
Old May 24, 2002 | 09:18 AM
JL 74's Avatar
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (ARACER25)
I have the beaks kit and I like it better only because it reinforces both sides of the subframe
I don't see the installation instructions in his website. Do you need to drill on the top and bottom holes, and also, how is the fitment?
Old May 24, 2002 | 11:26 AM
RineRacing's Avatar
I had the BSQ kit on my car with the 22mm ITR bar and put it through 30+ autocrosses (8 on R compund tires) and not a single sign of tear out. I just switched to a 23mm ITR bar and BSQ kit but I have yet to test it.
Old May 24, 2002 | 11:39 AM
BROOD's Avatar
You use an existing hole for the top bolt and drill out a hole for the bottom bolt. It is a fairly easy install. I also chose the Beaks over the BSQ because it contacts the subframe on both sides and offers more surface area to distribute the load over.
Plus, those are really purdy anodized aluminum parts.
SLPR........
Old May 24, 2002 | 01:15 PM
mercury's Avatar
New User
The Skunk2 arms are longer and are meant to be used with those D-bracket risers. If you remove the risers and attach the bar close to the frame with the BSQ or Beaks kit, your endlinks are going to be off at a pretty sharp angle. You need to find some other way to reinforce the Skunk2 bar.
People with 5g Civics usually pick the Beaks kit because they don't have the nuts welded into the subframe (which would have to be chiseled off) and they don't have the ABS sensor wire getting in the way. People with 3g Integras tend to pick the BSQ kit because they only have to whack off one nut.
Old May 24, 2002 | 01:16 PM
mercury's Avatar
New User
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (mercury)
...they only have to whack off one nut.
Gee, I should really read what I write before I hit the "post" button.
Old May 24, 2002 | 01:33 PM
JL 74's Avatar
hahahaa. you mean, one nut on each side right?
What about the high nut? Do you need to whack that off too for the beaks kit to fit?
Old May 24, 2002 | 01:38 PM
vtecdc2's Avatar
hahaahaaaahahha
Old May 24, 2002 | 02:07 PM
ARACER25's Avatar
There are 3 tack welded nuts on the inside of the subframe that need to be removed and the only hole that needs to be drilled (enlarged rather) is the small one on the bottom. I used a 5/16 bit (if I remember correctly) and it took about 1/2 sec to drill the hole a little larger. The fitment was almost perfect. I say almost because there is a very small portion at the bottom of the subframe that is bowed out and when I tightened the brackets and the reinforcement plates it smashed that very small part. Not a problem at all and if you were not looking for it you probably would never notice that it happened. Overall Beaks Products are outstanding as is his customer service (via e-mail). I am sure the BSQ kit is fine also but I liked Beaks better because of the reinforcement plates on both the inside and backside of the subframe. IMO it is better/stronger. http://www.beaksproducts.com/main.html
Old May 24, 2002 | 02:10 PM
JL 74's Avatar
So the upper part is reinforced also? Did you have to chisel off the upper nut?
Old May 24, 2002 | 02:12 PM
ARACER25's Avatar
Yes, all 3 nuts on both sides have to be removed. 6 total nut removals.
Old May 24, 2002 | 02:23 PM
B17-NA's Avatar
anyone know of the bsq website?
Old May 24, 2002 | 02:33 PM
JL 74's Avatar
Oops, I should have read your other post first. Thanks for the info.
Old May 25, 2002 | 11:24 AM
BSQ's Avatar
BSQ
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (whyujockin)
Here is the link to my Type-R rear swaybar mounting/reinforcement kit: http://www.geocities.com/bretq/mounting_kit.html
Here is the link to my Type-R rear swaybar installation instructions: http://www.geocities.com/bretq/swaybar_install.html
Old May 25, 2002 | 11:28 AM
JCushing's Avatar
Default Re: Ever been a case of sub frame tear using bsq or beaks kit? (BSQ)
is there any way to use your kit with a skunk2 bar?
Old May 28, 2002 | 05:54 PM
BSQ's Avatar
BSQ
You should be able to use the Skunk2 rear swaybar with my BSQ Type-R rear swaybar mounting/reinforcement kit. You will also need the Type-R swaybar bushings and bushing brackets. Let me know if you have any other questions.
teddy_dc2
Suspension & Brakes
May 27, 2007 06:39 PM
aw1234dude
38
Sep 26, 2004 09:48 AM
Maxboost808
Jun 16, 2004 02:01 PM
Kev95lx
Sep 26, 2003 05:54 AM
RedGSR
Jul 27, 2003 12:06 AM
