ZX300.1 Kicker Amp what sub to get
Old Mar 18, 2007 | 12:13 AM
lsvtek's Avatar
Default ZX300.1 Kicker Amp what sub to get
What Kicker subwoofer can I get that will sound good with this amp? Also it needs a 2 ohm or 4 ohm? Also I have a 2 subwoofer enclosure 10". I i will bridge
Old Mar 18, 2007 | 08:22 AM
fcm's Avatar
fcm
Old Fart
Default Re: ZX300.1 Kicker Amp what sub to get (LSintegra4)
The Kicker ZX300.1 is 1x300W RMS into 2 ohms, so if you want 2 subs, find two 150W 4 ohm subs, like the Kicker ES104, [150W continuous 4 ohm 10" sub.
There are many other brands that have 150W 4 ohm 10" subs. 94
Old Mar 18, 2007 | 01:17 PM
01d17's Avatar
Default Re: ZX300.1 Kicker Amp what sub to get (fcm)
get two 10" Kicker Comps.they are svc 4 ohm speakers and are 150 rms a piece. perfect match up for that amp
Old Mar 18, 2007 | 04:03 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01d17 &raquo;</TD></TR><TR><TD CLASS="quote">get two 10" Kicker Comps.they are svc 4 ohm speakers and are 150 rms a piece. perfect match up for that amp </TD></TR></TABLE> Even better, as they are 150W continuous, the ES104s are only 100W continuous it is the ES154 that are 150W continuous. 94
Old Mar 19, 2007 | 12:32 AM
Rev4Ever's Avatar
Default Re: ZX300.1 Kicker Amp what sub to get (01d17)
One 12" Kicker Soloberic is more than enough.
I love me setup. Hits hard!
Old Mar 19, 2007 | 09:14 AM
Rev4Ever's Avatar
Default Re: ZX300.1 Kicker Amp what sub to get (Rev4Ever)
Get to 10" SOLOBERIC L2 for the two openings. You won't regret it, trust me.
I've had many and heard many and I think the Kicker Soloberic are the best in my opinion.
Old Mar 19, 2007 | 11:36 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev4Ever &raquo;</TD></TR><TR><TD CLASS="quote">Get to 10" SOLOBERIC L2 for the two openings. You won't regret it, trust me.
I've had many and heard many and I think the Kicker Soloberic are the best in my opinion.</TD></TR></TABLE> What the hell is a "SOLOBERIC L2" there are L7s and L5s , even C and D series, and the S10L5 is a 450W sub, the S10L7 is a 600W sub.
The OP has 300W into 2 ohms to work with, how the hell is he going to properly drive even 2 L5s, 900W continuous? 94
Old Mar 19, 2007 | 11:45 AM
Rev4Ever's Avatar
SORRY, type-o. I have an L5 cause I got it for an incredible offer, but the newer one is L7. Their both awsome.
Old Mar 19, 2007 | 01:20 PM
mnizzy's Avatar
i dont think the L7's are newer just more powerful , 600 watts vs 450 i think.
Either way, two of these will match perfectly...
-Kicker C104 (couldnt find the ES104 or 154 like mentioned earilier) http://www.cardomain.com/item/KIC07C104
Old Mar 19, 2007 | 01:50 PM
Rev4Ever's Avatar
Default Re: ZX300.1 Kicker Amp what sub to get (mnizzy)
You must be talking about the RMS. The Power on my L5 is 1200 watts and 750 RMS.
Old Mar 19, 2007 | 01:51 PM
Rev4Ever's Avatar
The RMS on Kickers is incredible!
Old Mar 19, 2007 | 04:37 PM
lsvtek's Avatar
I have the C104 subs already. But after 25 on the volume, it doesnt wanna hit any harder. What can be the problem? Can it be the cheap wiring? I got some cheap wires with it. Was thinking of getting 8 Gauge Kicker wiring.
Old Mar 19, 2007 | 06:33 PM
mnizzy's Avatar
First off, IMO running two subs off 300 watts isnt going to get you hard hits if thats what your looking for.
You could start by making sure the gain is set correctly on the amp and headunit is tuned right for low frequencies, and u could also play around with teh direction the subs are firing in. As far as wiring goes, from what i've seen 8 awg wire from kicker isnt any better than 8 awg wire from a hardware store or ebay. Also make sure its grounded nicely with a short wire (&lt;18").
Otherwise save up the money and get a more powerful amp and some subs to boot.
Old Mar 19, 2007 | 07:14 PM
lsvtek's Avatar
I think if I upgrade my wires it will help, because right now after 25 on the deck, the subs sound the same even if i go to 30, it will sound like 25...
Old Mar 19, 2007 | 08:13 PM
Rev4Ever's Avatar
I'm running 4 gauge and no problems. Could be the wiring, but not to sure on that.
Old Mar 19, 2007 | 11:21 PM
Rev4Ever's Avatar
I just though of something. You might be getting resistance from something.
Old Mar 20, 2007 | 05:50 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rev4Ever &raquo;</TD></TR><TR><TD CLASS="quote">You must be talking about the RMS. The Power on my L5 is 1200 watts and 750 RMS.</TD></TR></TABLE> The S12L5 is peak 1200 RMS 600.
The S12L7 is peak 1500 RMS 750.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnizzy &raquo;</TD></TR><TR><TD CLASS="quote">i dont think the L7's are newer just more powerful , 600 watts vs 450 i think.
-Kicker C104 (couldnt find the ES104 or 154 like mentioned earilier) http://www.cardomain.com/item/KIC07C104 </TD></TR></TABLE> You are correct, the L5s and L7s are two diff. lines with 4 models each, 8" 10" 12" and 15" and the L7 have higher continuous power handling.
Although both are good subs, a pr. of 10" of either set are not appropriate for the amp that the OP has, Kicker ZX300.1, 1x150W RMS into 4 ohms and 1x300W RMS into 2 ohms, even a pr. of S10L5s is 900W continuous, hardly a perfect match. 94
Old Mar 20, 2007 | 07:28 PM
mnizzy's Avatar
Haha no way i ment that the L5 would match his amp (but i see where you got that, i wasnt clear in my typing). I was refrencing the link when i said "two of these would work fine"
Old Mar 20, 2007 | 09:32 PM
Rev4Ever's Avatar
I like KICKER's a lot.
Only if they worked with his amp.
JDMcivicSiEG6
Audio / Security / Video
Mar 12, 2008 09:02 PM
lsvtek
42
Feb 11, 2007 09:55 PM
teknoracing
30
Jun 7, 2006 03:42 PM
Ludeboi
Aug 26, 2004 06:57 PM
