Injecting fluid into brake bleeders...anyone use this method to bleed brakes?
Old Mar 18, 2007 | 12:12 AM
erikiksaz1's Avatar
Default Injecting fluid into brake bleeders...anyone use this method to bleed brakes?
I came across this thread (https://honda-tech.com/zerothread?id=1656908), where the guy was installing stainless brake lines on his bike. Anyways, in the bleeding process he used a baster/"injector" to push fluid through the bleeder, in order to force the air out through the master cylinder. Supposedly it should make for better bleeds because air has the tendency to rise.
The procedure for flushing your brakes would take a bit longer with this method, but what do you guys think?
Old Mar 18, 2007 | 02:48 AM
Kavehman's Avatar
would make sense for a bike as it doesn't hold as much fluid as a car, but i figure if you wanted to do this for a car you would need a bigger baster/syringe to do it right.
Bleeding brakes isn't that hard if you have a cheap bleeder kit
Old Mar 18, 2007 | 07:08 AM
01usjdmr's Avatar
That wouldn't work right for a car.
Old Mar 18, 2007 | 06:51 PM
drumking15's Avatar
vacuum bleder ftw!
Old Mar 18, 2007 | 07:16 PM
RagingAngel's Avatar
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">vacuum bleder ftw!</TD></TR></TABLE>
yup.
I use this and I think it's the best thing since brakes
found here:
http://www.griotsgarage.com/ca...85700
works great for bleeding clutches too!
Old Mar 18, 2007 | 07:43 PM
erikiksaz1's Avatar
Default Re: (RagingAngel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
yup.
I've heard that using the vacuum method will suck air past the hose where it connects to the bleeder, is that true?
Old Mar 18, 2007 | 07:51 PM
drumking15's Avatar
Default Re: (erikiksaz1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 &raquo;</TD></TR><TR><TD CLASS="quote">
I've heard that using the vacuum method will suck air past the hose where it connects to the bleeder, is that true?</TD></TR></TABLE>
yea it will if the hose isnt the right size...but it works still and just keep pumping until the fluid has 0 air in it...only way to do it one man'd
Old Mar 18, 2007 | 07:59 PM
cltitus's Avatar
actully that looks quiet nice makes it less messy
91akira
Oct 27, 2008 03:30 PM
Silvteg95
Aug 19, 2005 10:50 PM
H.crx-si
Jul 6, 2003 10:05 AM
RCautoworks
Apr 15, 2003 08:53 PM
Jordan_4WS
Jan 20, 2003 02:10 PM
