idle
Old Mar 17, 2007 | 02:51 PM
hai_tech's Avatar
Default idle
i hav question when i start my car everyday it start idle up n down and after 10-15 minute it stop n then i drove n it start idle again after i stop n put on newtro any idea
Old Mar 17, 2007 | 02:52 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: idle (hai_tech)
This makes zero sence. Do you mean your idle doesn't hold steady untill the motor is warm?
Old Mar 17, 2007 | 03:56 PM
hai_tech's Avatar
i mean when i start my car it keep idle up n down never stop like reving back n for
Old Mar 17, 2007 | 04:04 PM
Ass$nyper's Avatar
Default Re: (hai_tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hai_tech &raquo;</TD></TR><TR><TD CLASS="quote">i mean when i start my car it keep idle up n down never stop like reving back n for</TD></TR></TABLE>
Honestly, type better, I can't be any nicer.
So it doesn't hold an idle, how much is it going from is it a slight fluctation example 1200-1500 rpm or is it larger like 1000-2000 etc?
Have you replaced your electronics as of late, dizzy cap rotor spark plugs wires etc?
Old Mar 17, 2007 | 04:20 PM
HackAbuse's Avatar
It's most likely your FITV
Old Mar 17, 2007 | 05:51 PM
hai_tech's Avatar
Default Re: (Ace$nyper)
i havnt replace anything lately it idle 2000-2500 could be my iacv bad?
Old Mar 17, 2007 | 06:16 PM
garageEF's Avatar
check your coolant level and reset the ecu.
and learn to use 4th grade english at least
Old Mar 17, 2007 | 06:39 PM
Ass$nyper's Avatar
Look at replacing both the fitv and iacv but, more so I think you got it guessing your IACV being dead.
Old Mar 17, 2007 | 06:56 PM
hai_tech's Avatar
i did replace both FITV n IACV use but do i hav to bleed when installed the IACV or it will not werk property? mayb that the reason my engine surge up and down at idle
Old Mar 17, 2007 | 07:07 PM
SIred91's Avatar
Rainman
srsly.....
Edit: wtf is up with Max and the amazing changing screen names? lol
Old Mar 17, 2007 | 07:10 PM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hai_tech &raquo;</TD></TR><TR><TD CLASS="quote">i did replace both FITV n IACV use but do i hav to bleed when installed the IACV or it will not werk property? mayb that the reason my engine surge up and down at idle</TD></TR></TABLE>
you shouldnt have to bleed when replacing anything, but feel free
Old Mar 17, 2007 | 07:17 PM
Ass$nyper's Avatar
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
srsly.....
Edit: wtf is up with Max and the amazing changing screen names? lol</TD></TR></TABLE>
I get bored fast
Old Mar 17, 2007 | 07:18 PM
hai_tech's Avatar
Default Re: (garageEF)
mayb air in my coolant ?and how can i check coolant level and i will reset my ecu see wat happen thank for advice
Old Mar 17, 2007 | 07:19 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">
I get bored fast
Me too, wait....what?
Old Mar 17, 2007 | 07:20 PM
Ass$nyper's Avatar
Me too, wait....what?</TD></TR></TABLE>
How many ADD kids does it take to change a light bulb?
HEY LETS GO RIDE BIKES!!
Old Mar 17, 2007 | 07:21 PM
SIred91's Avatar
Rainman
Ride bik........I love couch!
Old Mar 17, 2007 | 07:26 PM
SIred91's Avatar
Rainman
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hai_tech &raquo;</TD></TR><TR><TD CLASS="quote">mayb air in my coolant ?and how can i check coolant level and i will reset my ecu see wat happen thank for advice</TD></TR></TABLE>
If you can't check your spelling....err....coolant level in a car, then you don't need to be driving it.
Turn the bleed screw on the inlet housing on the head out till coolant comes out. Then tighten the screw,then fill the radiator and reservoir up to the recommended levels. Then run the car till its warm with the radiator cap off, top off as necessary, and then put the cap back on.
Kindergarten car maintenance man.
Old Mar 17, 2007 | 07:28 PM
hai_tech's Avatar
aite kool thank
Old Mar 20, 2007 | 07:19 PM
EF88Vtec's Avatar
it your map sensor
Old Mar 20, 2007 | 07:26 PM
BlueRex1020's Avatar
Default Re: idle (EF88Vtec)
lol...
b18cisbetter
Dec 8, 2009 06:04 AM
RedR
Aug 4, 2008 04:38 PM
90_Si
26
Jan 22, 2008 06:38 PM
jcivicsib20
Mar 13, 2003 08:42 AM
