Alternator or Battery?
Old Mar 17, 2007 | 01:05 PM
SupraRXZ's Avatar
Default Alternator or Battery?
lately my sound system has a static noise that gets louder or worse as my RPMS go up, it goes with the flow of my engine speed, then my battery light turns on and my idle goes up and down (1k- 1.3k), but when i hit the gas and RPMs are above 3k the noise is gone and the battery light is gone
Old Mar 17, 2007 | 03:37 PM
Pooby88's Avatar
Default Re: Alternator or Battery? (SupraRXZ)
Sounds like your battery is weak. Check your battery voltage by touching the terminals with a voltmeter. You should have about 12 volts. You can test your alternator by touching the battery terminals with a voltmeter while the car is running. You should have about 14 volts at the battery with the car running.
Old Mar 17, 2007 | 03:40 PM
Gunmetal_B20_Hatch's Avatar
Check your grounds for amp and H/U.
Wrong section also... Try the Audio/Security section.
Old Mar 17, 2007 | 04:24 PM
brandoom's Avatar
An Hero
Default Re: (Gunmetal_B20_Hatch)
What kind of system. Watts/Amps
Old Mar 17, 2007 | 05:10 PM
SupraRXZ's Avatar
alright ill check it out, and my system is
1 JL 600 watt amp and a JVC 300 watt MP3 player and a single 12inch rockford punch stage 3
Modified by SupraRXZ at 2:43 PM 3/18/2007
mydogFahey
Honda CR-V & Element
10
Mar 29, 2015 09:59 AM
grkblood13
Jan 10, 2010 08:21 AM
fhukingviet
Audio / Security / Video
Nov 18, 2009 08:41 AM
97excoupe
Feb 27, 2002 12:01 PM
ck279
Jan 16, 2002 12:08 PM
