Greddy kit on GSR, questions.
Old Mar 17, 2007 | 12:52 PM
Mario's Avatar
Default Greddy kit on GSR, questions.
How is the clearance between the ex. manifold and the AC/Radiator fans?
I have a thicker Koyo aluminum radiator which leaves me with less room to work with, and would like to know if I can keep the OEM fans (w/ some trimming) or resort to a slim fan.
What other fitment issues are there with this kit?
TIA
Old Mar 17, 2007 | 01:04 PM
urbansi's Avatar
Default Re: Greddy kit on GSR, questions. (Mario)
You might have to trim the **** out of the stock fan for it to work, i had to trim mine a little and i was using a stock radiator. the block webbing will most likely have to be trimmed also to fit the turbo, nothing major though...
Old Mar 17, 2007 | 02:52 PM
95gsrturbo's Avatar
Default Re: Greddy kit on GSR, questions. (urbansi)
^^^ ditto
i recomend getting pusher fans and mounting them on th front of the rad, thats more space for you
Old Mar 17, 2007 | 03:27 PM
almostboostedgsr's Avatar
Default Re: Greddy kit on GSR, questions. (95gsrturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrturbo &raquo;</TD></TR><TR><TD CLASS="quote">^^^ ditto
i recomend getting pusher fans and mounting them on th front of the rad, thats more space for you </TD></TR></TABLE>
You mean (puller fans). Its better to use a puller fan than a pusher fan.
Id buy a half size radiator and one 12inch puller slim fan. Than you would be set.
Old Mar 17, 2007 | 03:38 PM
95gsrturbo's Avatar
Default Re: Greddy kit on GSR, questions. (almostboostedgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostboostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">
Id buy a half size radiator and one 12inch puller slim fan. Than you would be set. </TD></TR></TABLE>
no n00b- i mean PUSHER fans- that would create more space-
how is it any different puller or pusher- both are electric and as long as the fan rotates in the same direction as air flow in.
a pusher onthe front of the rad will give more E-bay space.
Old Mar 17, 2007 | 04:25 PM
First of all just because my icon says noob, doesnt mean im a noob to cars lol. Go to becool.com. It teaches you that puller fans work much better cooling the motor than a pusher fan does.
Im not stating my opinon on the fans its from information. There is a big difference from a pusher fan than a puller fan.
Old Mar 18, 2007 | 09:08 PM
95gsrturbo's Avatar
i didnt say you were new to cars- calm down dude - i used your name so you would know i was talking to you -- you chose the n00b sign
As well can you not agree that a pusher fan will increase space in the engine bay?
Old Mar 19, 2007 | 04:24 PM
Mario's Avatar
This will work even if I still have A/C? The A/C condenser is right in front of the radiator.
Anyways, thanks for the help. It looks like I'll have to sacrifice/modify more than I wanted to in order to utilize the "bolt-on" Greddy turbo kit.
I'm reluctant to decrease my cooling capacity by going to a half sized aftermarket radiator like most boosted DC I've seen. And, I don't feel like poking through the fins to mount/install slim electric aftermarket fans either (kind of cheesy IMO).
I'll just do tranny upgrades for now (LSD, clutch, flywheel). Just in case I change my mind in the future...my drivetrain will already be set for the extra power.
word to big bird
Old Mar 19, 2007 | 05:21 PM
You wont decrease your cooling campacity. Any aftermarket radiator is always going to be better an oem one. Unless the aftermarket radiator has a hole in the bottom.
Old Mar 19, 2007 | 06:08 PM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by almostboostedgsr &raquo;</TD></TR><TR><TD CLASS="quote">You wont decrease your cooling campacity. Any aftermarket radiator is always going to be better an oem one.
I agree with you.
However, what I am trying to say is that a half sized aftermarket radiator will decrease my cooling capacity from what I have now. Which is a full size Koyo aluminum upgrade.
Given that a boosted motor is going to generate more heat, I would much prefer to keep my current full size setup to be on the safe side. But that doesn't seem possible at this point.
stuie08
Jan 22, 2008 01:10 PM
sinfulDB1
May 7, 2004 10:59 AM
gsrhunny
Jan 7, 2004 09:39 AM
ID_ten_T
Aug 13, 2003 09:45 AM
Ri5e
Jun 19, 2002 07:47 PM
