ANOTHER Mini-Me question
Old May 23, 2002 | 01:40 PM
d357r0y's Avatar
Default ANOTHER Mini-Me question
Sorry to sound like a simple simon..but..
i am doing the swap next week and would like some input on the z6 and the y8 head gaskets and the advantages / disadantages of them.
thanks in advance
Old May 23, 2002 | 11:58 PM
Noahk's Avatar
Default Re: ANOTHER Mini-Me question (d357r0y)
Damn, I thought I knew but I forgot. Anyway I know for the Z6 you have two choices. Get the metal one with the rasied little bumps. The early ones had problems with blowing. I think there is a small difference in the Z6 and Y8 head gaskets. I'm pretty sure the Y8 is a little thicker, but not enough to worry about.
Old May 30, 2002 | 06:11 AM
mraudio13's Avatar
Hey i emailed u , incase u didn't get it i live in fwb and have done a mini-me swap you should contact me if you need to know anything.
matt, mraudio13@aol.com
Old May 30, 2002 | 06:32 AM
Speed PHreak's Avatar
there isn't much difference between the z6 and y8 gaskets, thinkness mostly. The Y8 is the thinner of the 2. What ever you do DON'T use an A6 haed gasket. I thought I could get away with using the cheaper gasket, but appreantly the water jacket holes on the a6 head gasket are too small, or don't line up right with the VTEC heads. Now the engine overheats before I can get out of my neighborhood. Guess i'll be doing the whole job over again
Old May 30, 2002 | 07:02 AM
d357r0y's Avatar
Default Re: ANOTHER Mini-Me question (Speed PHreak)
damn dood, sorry to hear that.. i sold my z6 head and im buying a y8 for less than i sold the z6 for.. so im gonna go with the y8 gasket after all
good luck with the new gastket
Old May 30, 2002 | 09:03 AM
Mugen Dom's Avatar
there is no a6 head gasket anymore the shity gasket was discontinued now they use the 92-95 dx one...y8 will give u the most compression.....use that and get new head bolts do go cheap on ur ****
stkinge
Jul 14, 2009 04:56 PM
burnt_rice
Feb 3, 2005 05:48 AM
beandip
Oct 28, 2004 07:25 PM
egturbo
Jun 19, 2004 07:07 PM
BlackFrog
Aug 29, 2003 03:23 PM
