GSR crank help
Hey whats up guys, well i bought a GSR block with a spun bearing. Only journal #3 is "scratched" well from what i can tell by running my finger over it. And i also have an eagle crank from a gsr which also spun a bearing. Now question is, is it worth trying to fix either or, or should i just buy another GSR crank? Thanks in advance. and any ballpark figures on how much it would cost?
an engine machine shop should be able to recut the crank then u use oversized bearings. what bearing spun, if it was a main bearing then the block needs to be line honed also. if it was a rod bearing then the rods need to be recut
oh ok... it was a rod bearing which spun on both the eagle crank and the oem gsr crank. i was in yonkers new york, but im now in miami again. sounds good, thanks for the help man.
Well, most people on here dont like eagle cranks. I have no personal expirience and it may just a bandwagon thing but i would look into it. As for an oem crank its usually just easier and cheaper to find a used crank in good shape instead of repairing the one you have. And that would be one less thing to have to worry about during your build.
acrocat
Jun 15, 2007 06:34 AM
