Tailights NOT working
Old Mar 16, 2007 | 08:43 PM
2camsaam's Avatar
Default Tailights NOT working
When i hit the brakes, none of my brake lights luminate.
When I turn my headlights on, the tails light up, however, when you hit the brakes they do not get brighter.
So the tailights are getting power, but don't get brighter when hitting the brakes.
What would cause this? I am thinking that its a fuse. If so, which one?
Old Mar 16, 2007 | 10:07 PM
Rev4Ever's Avatar
Default Re: Tailights NOT working (2camsaam)
I don't think it be a fuse cause it wouldn't work at all.
I think you're wires somewhere are shorting. The hard part is finding the culprit.
Old Mar 16, 2007 | 10:13 PM
Crashes's Avatar
Default Re: Tailights NOT working (Rev4Ever)
that or your brake light switch is out.
Old Mar 17, 2007 | 08:26 AM
paqman's Avatar
Default Re: Tailights NOT working (Crashes)
First things first. Check any fuses relating to the tail lights or brakes lights. If they are fine, this gets a little complicated. I would go right to the brake light switch near the brake pedal. First check and make sure everything is plugged in and mechanically working. After that check power and ground to that switch. I'm guessing the switch is the culprit, then again it is a guess.
Old Mar 17, 2007 | 08:44 AM
Rev4Ever's Avatar
Good luck in your quest my son. LOL
Old Mar 17, 2007 | 12:19 PM
2camsaam's Avatar
I just pulled every fuse under the hood and under the steering wheel. All are good. I checked all of the bulbs and all of the filaments are in tact.
I will go out and check the light switch. Not really sure what that looks like but you said it was near the brake pedal so...
2camsaam's Avatar
By the way, my car is completely stock. With the exception of my cd player.
Old Mar 17, 2007 | 12:31 PM
2camsaam's Avatar
I just checked the light switch. What I found looks like a short black stick screwed in with a white button on the end. When the pedel is depressed, the button is released.
I have an automatic tranny. When I depressed the pedal, the gear box clicks indicating that I can now move the gear stick and put it into R,N,D,2,1. Does this mean that the switch is functioning?
Old Mar 17, 2007 | 06:43 PM
Rev4Ever's Avatar
My girlfriend has an '05 automatic too with 11,000 miles. Her tranny shifter clicks like that too so it's functioning. Might be a short and that could be a bitch to find. Do you have warranty (my guess is no)?
Old Mar 17, 2007 | 10:26 PM
2camsaam's Avatar
Nope, no warranty.
HHEEEEEEEELLLLLLLLPPPPPPPPPPPP!!!
Old Mar 18, 2007 | 07:36 AM
2camsaam's Avatar
bump
Old Mar 19, 2007 | 01:10 AM
Aco512's Avatar
try switching out the bulb that you have the problem with
my girlfriend had this problem on her accord
i just swapped out the bulb for her and it works just fine now
good luck
Old Mar 21, 2007 | 07:16 AM
gents97civ's Avatar
First try new bulbs. Then go buy a new switch and see if that fixes it. If not take it back. After that break out a multimeter and start testing.
Old Mar 21, 2007 | 01:24 PM
BarracksSi's Avatar
It's highly unlikely that both brake light bulbs' brakes-only filaments burn out at the same time.
The layout for the auto tranny electrics says that the brake pedal position switch (which you appear to have been found) is indeed used for control of the transmission. It's used for the grade control, which determines a shift map depending on the slope that you're driving on. And, yes, it's used to unlock the transmission from Park.
So, yeah, that's kind of odd that the switch works for the transmission but not for the lights. There are four wires coming from the switch, though, so I would expect that one pair operate the brake lights and the other go to the transmission controller.
Do an electrical test as outlined in the pic here. A voltmeter isn't necessary; just a voltage tester with a light bulb will do.
heato
Jul 12, 2012 12:06 PM
Type-Spaz
Oct 2, 2011 04:44 PM
804tuned
Jan 14, 2010 07:50 PM
erikwithak
10
Aug 9, 2009 02:39 PM
-Whitey-
Feb 24, 2003 01:16 PM
