B16a6 Block/Gearbox separation.. Need quick adive how to separate the two
I have the block & gearbox (b16a6) out of my (stick) CRX Si and on a winch. I've undone (I believe) the five or so big bolts holding the gearbox to the block yet, I cannot seem to separate the two. is there a trick or am I missing a bolt? Thanks ina dvance.
SG -
SG -
there should be a total of seven bolts if I remember right, also did you take off the starter? And you will have to wiggle the block and trans apart a little bit too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF001282 »</TD></TR><TR><TD CLASS="quote">did you take off the starter? </TD></TR></TABLE> Friend of mine couldn't free the transmission, so he wedged in a massive pry bar and pushed until the block was no longer attached....being the genius he is the starter was still attached, along with a chunk of block
Starter off but I'll double-double check the number of bolts again. Might just have to do some intensive 'wiggling' & see how that goes.Spose a rubber hammer would't do too much damage so may have a whack with that too.
Thanks though.
SG -
Thanks though.
SG -
K_KrazyAzn
Dec 15, 2005 11:37 PM
