oil pressure sender unit..
Old Mar 16, 2007 | 04:56 PM
preludefien
Guest
Posts: n/a
Default oil pressure sender unit..
i just got rid of my oil pressure tach so i was putting the stock sensor back on. its been a while since i took it off but i wasnt sure how far the screw it in. i have heard that if you tighten it to far you can crack your block. but since its not screwed in all the way i have a minor oil leak. so should i go ahead and screw it all the way.
Old Mar 17, 2007 | 09:00 AM
satinsol's Avatar
Id say there has to be a torque spec sheet on this site with that on it since its on the block, if not then just tighten to where its as snug as it gonna get without over tightening it, cause you can always tighten it a little more and see if it keeps leaking. If you over tighten the first time and crack the block then your fucked basically
EFPhilly
19
Dec 24, 2009 04:51 PM
KooK
Nov 26, 2005 05:29 PM
EikoU
Oct 22, 2005 09:37 AM
gutted
Aug 20, 2005 09:55 PM
SIK IN DA HED
May 17, 2004 04:35 PM
