Stabilus Hatch Strut
Old Mar 16, 2007 | 04:25 PM
crr's Avatar
crr
Default Stabilus Hatch Strut
Anybody have any experience with these on an ITR or GS-R?
I found out from Acura today that the ITR and GS-R use the same hatch strut, but their prices range from $70-$90+ EACH (different dealers had different prices).
The Stablilus is cheap at about $27 each, but the description says it will fit ALL model Tegs. And I know the sub-GS-R models have a different strut.
Just wondering if anyone knows about this make and whether or not it's any good on the heavier Teg hatches.
Thanks.
Old Mar 17, 2007 | 07:19 AM
crr's Avatar
crr
Default Re: Stabilus Hatch Strut (crr)
Old Mar 17, 2007 | 07:32 AM
SE3Pimp's Avatar
try it out and let us know
Old Mar 17, 2007 | 07:49 AM
crr's Avatar
crr
Default Re: Stabilus Hatch Strut (EndlessDc2)
I am. I will.
Old Mar 26, 2007 | 05:45 PM
crr's Avatar
crr
I received and installed the Stabilus hatch struts today. They appear to work. The hatch lifts with little effort, and after about 3/4 of the way up, it will continue unaided. Albeit slowly. They mount up very easily, and look similar to OEM - with one big exception: they're upside down. As you can see in the photo, the body is at the top and the piston is on the bottom.
Modified by crr at 7:14 PM 3/26/2007
Old Mar 26, 2007 | 06:13 PM
get RIGHT's Avatar
Was there any modifacation needed?
Old Mar 26, 2007 | 06:20 PM
crr's Avatar
crr
Default Re: Stabilus Hatch Strut (ITR 00-0477)
No, they went on very easily. The only thing I did was reuse the snap ring, as the replacement snap ring didn't attach as securely.
Oh, I guess there was one mod - I sanded off the end of one of the nylon bushings that slides inside the tab on the middle photo. The end of it covered the groove where the snap ring goes, so I made it shorter with sand paper. Not a big deal. They were both mounted in about 30 minutes.
Make sure you have something securely propping up the hatch while you work. One strut isn't enough to hold it up - even if it's good. And you don't want it falling on your head!
Old Mar 26, 2007 | 06:27 PM
zc911's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crr &raquo;</TD></TR><TR><TD CLASS="quote"> And you don't want it falling on your head! </TD></TR></TABLE>
a ****** men to that, i have taken mine twice in the back. Broom handles don't work so well
Old Mar 26, 2007 | 06:33 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Stabilus Hatch Strut (zc911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zc911 &raquo;</TD></TR><TR><TD CLASS="quote">
a ****** men to that, i have taken mine twice in the back. Broom handles don't work so well </TD></TR></TABLE>
A lacrosse stick is perfect for Boxy's tailgate. Might work for an Integra as well.
Old Mar 26, 2007 | 06:45 PM
EG8R's Avatar
Default Re: Stabilus Hatch Strut (Splat)
I work at a Honda dealer. I've replaced many hatch struts. I've noticed that some Honda OEM struts are made by Stabilus. So I would trust the brand.
Old Apr 2, 2007 | 04:23 AM
professorman's Avatar
Default Re: Stabilus Hatch Strut (skelly ed666)
I put those same ones on my Integra recently. Its working great so far.
Neomoogle
Nov 6, 2011 03:04 PM
JJW
May 5, 2009 08:27 AM
crr
Mar 17, 2007 04:22 PM
chhuong
Aug 18, 2003 10:52 AM
93SSPHatch
May 10, 2002 11:39 AM
