4-1 headers vs. 4-2-1 headers
Old May 23, 2002 | 12:45 PM
Ekco's Avatar
Default 4-1 headers vs. 4-2-1 headers
I am wondering which ones I would get a better use out of. I don't plan on getting a turbo anytime soon, and everyone says that 4-1 is better for high output/range while 4-2-1 is better for mid-range. What does this mean? Please advise. Thanks
Old May 23, 2002 | 12:46 PM
hybridreams's Avatar
Default Re: 4-1 headers vs. 4-2-1 headers (Ekco)
4-1 - more pull at high rpms
4-2-1 - pulls harder in mid rpms
Old May 23, 2002 | 12:51 PM
94CivicSi's Avatar
I'll give ya 2 reasons why 4-2-1 is better, performance aside:
1) service: If you have to drop the pan, removes the clutch access cover, remove the tranny, whatever, it's a lot easier to separate the 2 pieces than it is to separate the header from the head and guide it out the bottom between the radiator and motor.
2) clearance: That collector has got to hang REALLY low on the 4-1. If you dimple that collector, you're going to restrict it's flow a lot. You only have to smack it once to damage it.
Old May 23, 2002 | 12:53 PM
Halo's Avatar
Default Re: 4-1 headers vs. 4-2-1 headers (94CivicSi)
http://www.importreview.com
Old May 23, 2002 | 01:04 PM
rodrez.'s Avatar
It just depends on what you plan on using your car for. The 4-2-1 will give you more midrange which is great for passing cars on the road. But the 4-1 will give you more top end pull, which is good if your motor is Vtec, cause you get more kick on the top. As far as clearance problems, I'm using a DC 4-1, and I have 15 inch rims with 205-50-15 tires, and I never scrape my header. Had the same ones for over a year now w/out any problems.
Old May 23, 2002 | 02:48 PM
CivicEx95's Avatar
Default Re: 4-1 headers vs. 4-2-1 headers (rodrez)
I scraped my 4-1 header on some speed bumps. Then I raised my coilovers up a couple turns and its been cool.
Old May 23, 2002 | 03:06 PM
Kamin's Avatar
um just because its 4-2-1 dosent mean its 2 peice
i have a 1 piece 4-2-1 header.
Old May 23, 2002 | 03:33 PM
YodaIsGod
Guest
Posts: n/a
Default Re: 4-1 headers vs. 4-2-1 headers (KAMiN)
4-2-1 for mid range gains
4-1 for high end gains
your choice.
Old May 23, 2002 | 03:46 PM
ALLMOTOR18's Avatar
your choice.
it all evens out at the end.. you sacrifice one range for the other..
ust depends onwhat kind of driving you do..
4-1 works well for me.. i thought i felt a big difference with the 4-1 compared to the 4-2-1, but that was with the *** dyno..
peace
JuanK20
Dec 27, 2004 09:52 PM
IntegraGSR321
Sep 30, 2003 06:16 PM
integsr99
Jul 8, 2003 10:30 AM
The new guy
Dec 1, 2002 02:17 PM
you2envious
Feb 6, 2002 06:55 AM
