JDM GSR cams & USDM ITR cams.... Same thing?
Old May 23, 2002 | 12:44 PM
InfamousRS's Avatar
Default JDM GSR cams & USDM ITR cams.... Same thing?
Some one told me the cams profiles are the same. Is there any truth to this?
Im thinking about buying a more agressive OEM cam to replace my b16 cams, but do not want to spend an arm and leg on them. I found a set of JDM GSR cams for a good price, are they worth buying?
Old May 23, 2002 | 01:37 PM
Jackson's Avatar
Default Re: JDM GSR cams & USDM ITR cams.... Same thing? (InfamousRS)
jdm gsr cams=usdm gsr cams. Not worth the money or hassle to switch them out. Just get ITR/CTR cams if you want oem.
Old May 23, 2002 | 02:01 PM
InfamousRS's Avatar
Default Re: JDM GSR cams & USDM ITR cams.... Same thing? (Jedi Master)
I just want somthing a little more agressive for now. Later this summer when I am done with my bottom end, I will get Skunk2 Stage 2 cams. I can get a set of JDM GSR cams for like $75, and it takes me less then a hour to install and do a valve adjustment. Can somone post the cam profiles of the JDM b16a cam and GSR?
Old May 23, 2002 | 02:44 PM
Reid's Avatar
Global Moderator
B16 cams < USDM/JDM GSR cams < 97-98 USDM ITR/95-97 JDM ITR cams < CTR/98+ JDM ITR cams
Why waste the money if you're getting Skunk cams laters? It's really not worth it.
Old May 23, 2002 | 04:22 PM
InfamousRS's Avatar
Default Re: JDM GSR cams & USDM ITR cams.... Same thing? (Reid)
Is the skunk 2 cam more aggressive than the CTR? I have never seen the numbers on the CTR so I am only assuming that they are.
Old May 23, 2002 | 05:56 PM
SurferX's Avatar
I thought B16A and B18C1 cams had the exact same profile?
Old May 23, 2002 | 06:54 PM
Michael Delaney's Avatar
Default Re: JDM GSR cams & USDM ITR cams.... Same thing? (SurferX)
yep they sure are....
http://g-speed.com/pbh/b16a/
Old May 23, 2002 | 07:24 PM
Doctor CorteZ's Avatar
depends on what year B16 also , as the year increases the cams get a little better as well
jyracer
Nov 4, 2009 05:14 PM
2000r#0283
Aug 18, 2005 05:48 AM
Duo57
Aug 13, 2004 01:38 PM
jDMJeRk
Feb 24, 2004 01:41 PM
clemens
Sep 4, 2002 09:00 PM
