OBD1 B18C into CRX - Almost done, few questions
Old Mar 16, 2007 | 02:42 AM
JUN1OR's Avatar
Default OBD1 B18C into CRX - Almost done, few questions
I must say this has been a pretty easy swap with all the good writeups. Props to droppedcrxsi and his great howto (http://www.norcalcrx.org/droppedcrxsi/) and to these other great links/threads:
https://honda-tech.com/zerothread?id=945557
http://www.rywire.com/store/im...r.gif
http://www.norcalcrx.org/dropp...s.jpg
I do have a few questions:
94 B18C1 --> 91 CRX Si
1.) What is this CRX sensor? (Back of the intake manifold)
2.) What is this GSR sensor? (under intake manifold, sorta by knock)
3.) I kept the GSR intake mani, but my fuel filter hits the intake tubing. I think I'll just relocate a few inches lower.
4.) (I can search this one... ) what about the mechanical vs electrical VSS?
Everything else is ready. I'm sticking with obd1 on the injectors so I repinned the injector clips, eliminated the injector resistor box by repinning the OBD1 block-off. Also distributor repinned, fan switch relocated, backup switch soldered, VTEC subharness is next to-do. Any other wires need to be extended? IAT, TPS, EACV? no? (I'll find out with trial and error)
Thanks to all who respond
Jun1or
Old Mar 16, 2007 | 05:57 AM
Andy R's Avatar
Default Re: OBD1 B18C into CRX - Almost done, few questions (JUN1OR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN1OR &raquo;</TD></TR><TR><TD CLASS="quote">
94 B18C1 --&gt; 91 CRX Si
Jun1or</TD></TR></TABLE>
1. Majestic Honda just lists it as a valve assembly, looks like it has something to do with vacuum assembly:
2. Not sure what that is, but looks like its related to vacuum again.
4. If you use mechanical, you can keep your stock instrument panel in the dash. If you go electronic, you'd have to convert over to obd1 type clusters (gsr, civic si...)
Old Mar 16, 2007 | 08:29 AM
JUN1OR's Avatar
Default Re: OBD1 B18C into CRX - Almost done, few questions (Andy R)
As I suspected on all. Thanks for the reply.
Old Mar 16, 2007 | 08:39 AM
Furyof4's Avatar
2. IAB solenoid
4. Use the mechanical one.
Old Mar 16, 2007 | 08:40 AM
wiZCo's Avatar
Stouts 'n' Scotch
Isn't #1 the FICV?
Old Mar 16, 2007 | 08:52 AM
ESP-net
Guest
Posts: n/a
Default Re: OBD1 B18C into CRX - Almost done, few questions (Furyof4)
#2 is definetly IAB (secondaries) hook it up to the vtec solenoid, kinda neat and cool, when hooked to vtec sol. wire (spliced in) secondaries will open upon vtec
on the 2 wire plug, 1 will go to a ground on the engine and the other to vtec sol. wire.
As far as the electronic speedo toss it, use a 90+ DA speedo unit mechanical if that doesn't work I beleve even a D series 88-91 Civic speedo unit may work. Both are junkyard items.
Old Mar 16, 2007 | 09:53 AM
JUN1OR's Avatar
Default Re: OBD1 B18C into CRX - Almost done, few questions (ESP-net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP-net &raquo;</TD></TR><TR><TD CLASS="quote">#2 is definetly IAB (secondaries) hook it up to the vtec solenoid, kinda neat and cool, when hooked to vtec sol. wire (spliced in) secondaries will open upon vtec
As far as the electronic speedo toss it, use a 90+ DA speedo unit mechanical if that doesn't work I beleve even a D series 88-91 Civic speedo unit may work. Both are junkyard items.</TD></TR></TABLE>
Edited- Yep #2 is the IAB secondary butterflies. Thanks yo. (I had the EVAP purge and IAB mixed up in my head - do I need the EVAP hooked up?)
Found this nice thread: https://honda-tech.com/zerothread?id=1077854
On the Speedo sensor, I do have the oem 91 CRX Si mechanical, but it seems affixed to the tranny, am I wrong here? EDIT - I guess I lock on it with a vice and tug. Fun.
Thanks for the help yo
Modified by JUN1OR at 1:53 PM 3/16/2007
ed4doorcivic
Nov 28, 2009 09:10 PM
gursh d
11
May 22, 2008 10:52 AM
jdmcz32
Aug 13, 2004 01:07 AM
1SIKCRX
Jun 17, 2004 05:18 PM
