Hiding alarm antenna
Old Mar 15, 2007 | 10:52 PM
ninjarich2's Avatar
Default Hiding alarm antenna
When doing a "stealth install" for an alarm, where do you guys put the antenna? Since you are only given a short length of wire, is it hidden as well? If so, how much range do you lose?
Old Mar 15, 2007 | 10:57 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Hiding alarm antenna (ninjarich2)
I allways put the ant in the front window or the back window. If the alarm is stealth there is enough wire to put it there. You can hid the ant but the range will suffer. Its up to you.
Old Mar 15, 2007 | 11:01 PM
ninjarich2's Avatar
Default Re: Hiding alarm antenna (wrx-killer-Sti eater)
Since the wire can be traced back to the brain, do you just make it so the brain is inaccessible?
Old Mar 16, 2007 | 01:56 AM
all the time not one of my cars that I done have ever been stolen ( knock on wood) And 4 have been atempted at this year with no go
Old Mar 16, 2007 | 08:05 AM
BubblegumTate's Avatar
Yeah, with the newer DEI's that are 2way, you get something like 9 or 10 feet of antenna cable. More than enough to put the antenna where it gets good reception, but far away from the brain.
Old Mar 16, 2007 | 10:05 AM
laos619's Avatar
Modified by laos619 at 12:11 PM 3/26/2007
tyronne1126
Audio / Security / Video
Mar 3, 2009 09:22 AM
superthug
Sep 7, 2003 07:17 AM
SilverDc2
11
Jun 26, 2003 10:34 PM
civictypenos
Mar 26, 2003 06:45 AM
Undepelo
10
Aug 29, 2002 11:58 AM
