Running to rich how should i fix it or lean it out a little bit?
Old Mar 15, 2007 | 09:07 PM
Plo8618's Avatar
Default Running to rich how should i fix it or lean it out a little bit?
IS it the best idea to retard my timing or advance my timing? for it to not run so rich. Or is it best to make my spark plug GAP bigger? whats the furthers gas spc. on a LS motor. i set mine to .036 i think thats the smallest. does any one know what is the furthers GAP? is it .044?
Old Mar 15, 2007 | 09:36 PM
Luserkid's Avatar
Default Re: Running to rich how should i fix it or lean it out a little bit? (Plo8618)
How do you know your running rich? If its a stock motor run a P75 ecu. If its a built motor go get it tuned.
Old Mar 15, 2007 | 09:38 PM
Eran's Avatar
HT White Ops
Stock gap is .044
Old Mar 19, 2007 | 06:43 PM
Plo8618's Avatar
Default Re: (Eran)
i rebuilt half of it i put the head gasket in it but i got it to not smoke any more so its all good.
Old Mar 19, 2007 | 06:58 PM
AntiochOG's Avatar
Default Re: (Plo8618)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plo8618 &raquo;</TD></TR><TR><TD CLASS="quote">i rebuilt half of it i put the head gasket in it but i got it to not smoke any more so its all good.</TD></TR></TABLE>
Which half did you rebuild?
CivSiClone_96
Sep 14, 2009 09:59 PM
poormans_typer69
Oct 3, 2007 02:32 PM
dangerranger21
Jul 9, 2006 09:55 PM
4gnhatch
Jan 17, 2006 05:29 AM
hatchback_al
May 18, 2004 08:09 PM
