What bolts for Tilton flywheel
Old Mar 15, 2007 | 06:40 PM
nitroice40's Avatar
Default What bolts for Tilton flywheel
I got the 6lb twin disk setup and went to install it today and the stock b series flywheel bolts are to long. Called tilton and he told me to grind them down (ghetto as hell) I told him no way I was going to do that. Then he asked someone and the other guy said D series bolts will work. So is this true? What are you guys using?
Old Mar 15, 2007 | 07:35 PM
HiProfile's Avatar
Default Re: What bolts for Tilton flywheel (nitroice40)
Measure yours and I'll measure mine
I have more than a bunch of them laying around, I'll go measure them right now & let you know.
edit: M12x1.00, 20mm long for d-series flywheel bolts.
Old Mar 15, 2007 | 07:54 PM
nitroice40's Avatar
Default Re: What bolts for Tilton flywheel (HiProfile)
The ones I have are 29.2mm long. that is measuring the whole bolt from the very end to the very end, not just the threaded part.
Old Mar 16, 2007 | 04:43 AM
nitroice40's Avatar
Old Apr 14, 2007 | 05:49 PM
BoOsTiN Dc2's Avatar
not sure if you found out yet... but the D series bolts are shorter and thats the one you'll need. Dont forget to grind down the bolts on the pressure plate and you might need to shave a little bit from the clutch release bearing... i think thats what its called...
Old Apr 14, 2007 | 06:10 PM
Jared's Avatar
You need D m/t bolts.
Old Apr 15, 2007 | 06:03 AM
nitroice40's Avatar
Default Re: (Jared)
Ya, I used the d series bolts for the flywheel. And I fliped the PP bolts around the other way and they cleared fine. You would think they would tell you in the directions about that.
Old Apr 15, 2007 | 07:28 AM
DaveF's Avatar
we used the ARP off the shelf bolts for the honda b series engines, then had them machined down to the proper length.
jrsh0526
Jan 24, 2014 06:27 PM
cranker
Jun 16, 2010 05:39 AM
team1320_k26eg
Jan 13, 2007 05:35 PM
Boosthead
Dec 30, 2004 04:40 PM
