are crossthreads better than no threads on wheels
Old Mar 15, 2007 | 06:27 PM
361 accord's Avatar
Default are crossthreads better than no threads on wheels
yeah, it sux, one lugnut is crossthreaded, and so is one bolt, cuz i teted it with another lugnut to see is it was the nut OR bolt that was bad...
anyways, i thiiink im gonna need a new hub, or no? can i just get 1 bolt
as for quality, can the different colored tuner nuts sold at like autozone be just as good
Old Mar 15, 2007 | 06:34 PM
1baddturbosi's Avatar
Default Re: are crossthreads better than no threads on wheels (361accord)
so.... it sounds like u need a new lug nut & wheel stud. u should be able to get them at an autozone store and they are pretty easy to put on. this stuff happens all the time.
Old Mar 15, 2007 | 06:51 PM
Loco-B's Avatar
Yeah pretty easy fix! New wheel stud and a new lugnut will do the trick. Like he said your local A.Z. or dealership will carry that stuff in stock! No need to replace the hub and wheel bearing.
Old Mar 15, 2007 | 06:55 PM
Default Re: are crossthreads better than no threads on wheels (accordcd_7)
go buy a new wheel-stud and lug nut, pound that old one out, put the new one in. and then your DTR (down the road)
Old Mar 15, 2007 | 11:16 PM
361 accord's Avatar
oh man i feel better, any ideas of how the process goes to take the stuff of, and back on?
Old Mar 16, 2007 | 06:52 AM
i_kick_turtles's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 361accord &raquo;</TD></TR><TR><TD CLASS="quote">oh man i feel better, any ideas of how the process goes to take the stuff of, and back on?</TD></TR></TABLE>
Hammer the old one out. Pull the new one back through with a nut and washer. Really very easy.
Old Mar 16, 2007 | 07:54 AM
TouringAccord's Avatar
H-T Order of Merit
A couple quotes from a thread from a couple years ago...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GrandMarkie &raquo;</TD></TR><TR><TD CLASS="quote">I've replaced all my studs on my 95 EX without removing the hub/rotor. It actually takes about 15 mins per wheel.
1. Take off wheel
2. Take off caliper
3. Line up the stud you want to remove to the area where the caliper is mounted. Take a hammer to the stud and it will pop right out.
4. Hammer a new one in from the back of the hub. There is just enough room to put the stud in since you removed the caliper. Another way to pop the stud in is to put the new stud in, put some washers over the stud and then tighten the lugnut over the washers. This will pop the stud in good and tight.
5. Rotate the hub to line up the next stud and repeat.
Viola!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">if u have a problem putting the new stud in, take it and grind part of the head off ,it will give u enough room to put it in </TD></TR></TABLE>
sixfiveoh
Dec 12, 2006 08:10 AM
vidanator
Oct 25, 2005 10:53 AM
windcalmer
Aug 7, 2004 12:08 PM
JDM_EK3
Jul 6, 2004 01:07 PM
92LudeSI
May 31, 2004 09:09 AM
