shocks and springs
Old Mar 15, 2007 | 04:59 PM
accord03coupe's Avatar
Default shocks and springs
hi, i own a 95 prelude vtec. the car have 200k miles on the body. i need to change the shocks and springs, and i want to low the car an inch or two. i need your suggestions on the set up. but i don't want to spend too much though.
thank!
Old Mar 15, 2007 | 05:07 PM
glazethatj's Avatar
Default Re: shocks and springs (accord03coupe)
neuspeed sport springs lower about 1.7 up front and 1.5 in the back. tokico blues are a good set of shocks imo
Old Mar 15, 2007 | 06:46 PM
M2B4's Avatar
Default Re: shocks and springs (glazethatj)
im gunna recommend ground control paired with koni yellows or kyb agx.
im on GC now and when i replace my shocks 1 of those 2 are going in.
Old Mar 15, 2007 | 09:39 PM
Default Re: shocks and springs (M2B4)
shocks, springs, ground control.
how much is that set up will cost?
can i use tein sprins with stock shocks?
thank!
Old Mar 15, 2007 | 10:22 PM
Oregon's Avatar
* B A N N E D *
ebay
Old Mar 15, 2007 | 10:30 PM
M@'s Avatar
M@
I think it would help if you listed your needs/goals for the car. Whats your budget? Are you going to go toward Auto-X? Are you just going to pick up chicks? Are the chicks fat?
Old Mar 16, 2007 | 04:29 AM
mrkrooz's Avatar
how much are GC sleeves and kyb agx shocks these days...??
Old Mar 16, 2007 | 05:51 AM
carnot's Avatar
with 200k miles on the chassis you should also think about the condition of your bushings. replacing shocks and springs without knowing the condition of the bushings may cause some drawbacks.
Old Mar 16, 2007 | 06:09 AM
hu's Avatar
hu
Default Re: (mrkrooz)
GC springs are $339 directly from GC and you can choose custom spring rates. I went with 440f and 550r.
Old Mar 16, 2007 | 10:41 AM
1GPlusSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">im gunna recommend ground control paired with koni yellows or kyb agx.</TD></TR></TABLE>
I have koni yellows and skunk2, but I wish I had gone ground control. The price is a lot better, and you can custom order your rates.
Don't use your stock shocks if you lower your car. You'll end up replacing them once they make your car start bouncing because they're worn out.
doglovindork
Sep 15, 2004 09:50 PM
LiLn81224
Dec 13, 2002 01:25 AM
mini-cRx
Jul 22, 2002 04:31 AM
ebelp
Feb 16, 2002 07:40 PM
