Are prop valves REALLY necessary??
Old May 23, 2002 | 10:38 AM
fowler!'s Avatar
Default Are prop valves REALLY necessary??
My friend has 99-00 Si rear brakes on his 92-95 Ex coupe.
We were thinking about upgrading the prop valve, but don't know whether or not it's worth the time..
any suggestions?
after checking the FAQ, the best prop valves would be a 92-95 Si or a 90-93 Integra, right?
tia
Old May 23, 2002 | 12:45 PM
meept's Avatar
Default Re: Are prop valves REALLY necessary?? (fowler)
The purpose of the prop valve is to set the front/rear brake bias, I think. Without it, you'd be prone to locking the rear wheels, as the rear brakes would grab just as hard as the fronts. I've always heard that using the one from the donor vehicle (or one with similar brake setups) was recommended. Personally I'd be inclined to fit an adjustable one like Wilwood makes, but I'm the kind of person who wants to tinker with everything....
Old May 23, 2002 | 01:45 PM
bretx0r's Avatar
Default Re: Are prop valves REALLY necessary?? (meept)
yeah you need it.
Old May 23, 2002 | 02:31 PM
Crazydave's Avatar
Default Re: Are prop valves REALLY necessary?? (bretx0r)
I think they are a good thing...
but if they are is not handling or braking bad.. don't worry about it.
If you want to be able to adjust it
then get it
[Modified by Crazydave, 11:32 PM 5/23/2002]
SideFX
18
May 4, 2011 12:31 PM
SoCal EJ1
Suspension & Brakes
Oct 31, 2008 07:38 PM
BluGTIVR
Apr 23, 2004 01:33 PM
misledyouth
Jan 27, 2003 09:19 PM
fowler!
May 23, 2002 06:08 PM
