battery cable?????
Old Mar 15, 2007 | 01:57 PM
jdmyoo's Avatar
Default battery cable?????
i am planning on puttin the battery in tho boot. jst i have bout some 4 gauge wire. is that capable of taking the power. or what cable would you recomend,
cheers..
Old Mar 15, 2007 | 01:59 PM
Padawan's Avatar
Darth ModerVader
Default Re: battery cable????? (jdmyoo)
I would recommend 2-gauge or 0-gauge.
jdmyoo's Avatar
Default Re: battery cable????? (Padawan)
is 4 gauge no good then. or will it do..
thanks 4 reply.
Old Mar 15, 2007 | 02:39 PM
Padawan's Avatar
Darth ModerVader
4-gauge is passable, but if I were doing it, I'd go with something heavier.
Old Mar 15, 2007 | 03:24 PM
Formula's Avatar
I used 2 gauge on my old EF hatch and never had a problem.
Old Mar 15, 2007 | 03:25 PM
pdiggitydogg's Avatar
4 is on the small side
I used 0gauge
Old Mar 15, 2007 | 04:00 PM
Eran's Avatar
HT White Ops
My cousin's audio shop sells this really neat flexible 0'g wire, that would work nicely. It's called Stinger EXPERT 1/0 Gauge.
Modified by Eran at 5:22 PM 3/15/2007
Old Mar 16, 2007 | 10:34 AM
jdmyoo's Avatar
thanks 4 the help..
by the sounds of it my 4 gauge stuff should be passable.
think i am gonna go with it..
cheers
Old Mar 16, 2007 | 10:40 AM
ARMED's Avatar
4 should be fine....
Old Mar 16, 2007 | 10:53 AM
lol you get told repeatedly that you really should go with something larger...and decide not to listen.
Ok...
Old Mar 16, 2007 | 07:06 PM
jdmyoo's Avatar
Default Re: (pdiggitydogg)
well seen as i already have 4 gauge and people said its ok but would be better with a larger 1. i thought i may aswell go with that.
cheers
Old Mar 16, 2007 | 07:14 PM
rip94delsol's Avatar
Default Re: (jdmyoo)
I spoke with a tech @ taylor battery cables and he said it all depends on how long the wire is going to be!
he asked me what gauge and how long I was using and looked it up on his computer or system and said I would barely be passing with 2awg @ 12ft...
honestly alot of people run 2awg as their feed or power wire but theoritically 1/0 or 2/0 should really be used.... since the system you are running runs @ about 120-160 amps.....
I ran 2awg only because thats what was supplied through the taylor kit that i never used except for the wire and connectors
Old Mar 16, 2007 | 07:31 PM
ARMED's Avatar
i say if youre running a sound system..yes...
Old Mar 16, 2007 | 07:37 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (ARMED)
4 gauge will be fine. I work in a stereo shop, and one of the guys was showing me a little book on electrical laws. normaly with a 500 watt amp or so you run 4 gauge wire. According to the elctrical law calculator/reference chart in theory 8 gauge would be more then overkill. Search around online for the calculator.
Old Mar 16, 2007 | 07:47 PM
allricedout's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">My cousin's audio shop sells this really neat flexible 0'g wire, that would work nicely. It's called Stinger EXPERT 1/0 Gauge.
Modified by Eran at 5:22 PM 3/15/2007</TD></TR></TABLE>
how much is that?
Old Mar 16, 2007 | 08:14 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (allricedout)
also- try kicker amp wire- its very flexible great stuff!
Old Mar 16, 2007 | 09:06 PM
Default Re: (vestalfootball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 &raquo;</TD></TR><TR><TD CLASS="quote">According to the elctrical law calculator/reference chart in theory 8 gauge would be more then overkill. </TD></TR></TABLE>
So are you saying that 10awg is sufficient since 8awg is overkill?
**** waiting for your response*****
Old Mar 16, 2007 | 09:13 PM
vicious26's Avatar
Default Re: (rip94delsol)
um, yeah, you'll want 1/0 power wire.
also make sure you seal the battery in its own enclosure and have an open vent to the outside. even yellow tops emit gasses that can be flammable.
Old Mar 16, 2007 | 09:16 PM
Luserkid's Avatar
Also i highly recommend running an inline 150amp fuse, just incase if anything were to happen it could pervent possible fires.
Old Mar 16, 2007 | 09:26 PM
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Also i highly recommend running an inline 150amp fuse, just incase if anything were to happen it could pervent possible fires. </TD></TR></TABLE>
Yes and No! reason being that the stock fuse box(under hood) already has a fuse in it....
All your doing is extending lines and nothing else and still keeping the stock fuse box so your still kool....
Old Mar 18, 2007 | 10:26 AM
jdmyoo's Avatar
so will 4 gauge be ok i am running it from the fuse box to the boot on my civic hatch. lenght should eb approx 2.5 mt.
also
"make sure you seal the battery in its own enclosure and have an open vent to the outside."
any sugestions how i do this.
cheers 4 all the replys
Old Mar 18, 2007 | 10:27 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmyoo &raquo;</TD></TR><TR><TD CLASS="quote"> so will 4 gauge be ok i am running it from the fuse box to the boot on my civic hatch. lenght should eb approx 2.5 mt.
also
cheers 4 all the replys</TD></TR></TABLE>
Don't use 4g. Use 1/0.
Old Mar 18, 2007 | 10:39 AM
Default Re: battery cable????? (Eran)
taylor makes a battery box with all the supplies needed! also in that kit comes about 13 of 2awg and thats what i used...
i'll get a pic of the box in a bit
Old Mar 18, 2007 | 10:43 AM
jdmyoo's Avatar
Default Re: battery cable????? (rip94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rip94delsol &raquo;</TD></TR><TR><TD CLASS="quote">taylor makes a battery box with all the supplies needed! also in that kit comes about 13 of 2awg and thats what i used...
i'll get a pic of the box in a bit </TD></TR></TABLE>
cheers mate. do u think its poss to mate ur own..
cheers
Old Mar 18, 2007 | 03:30 PM
Padawan's Avatar
Darth ModerVader
Yes and No! reason being that the stock fuse box(under hood) already has a fuse in it.... </TD></TR></TABLE>
You're still running a long cable carrying a lot of current from the rear to the front of the car. A fuse should be installed near the battery.
