Fresh tune by InlinePro. NICE!
Just picked up my car from inline...the car made 190 at the wheels when I bought it. After 2 1/2 years I decided it was time for a fresh tune, and who other to go to then Inline, right up the street from me. The car made 206whp, a nice improvement, and it pulls hard until 9.5k. Ill do my best to get my dyno sheet up here, but Im always here at work. The setup is a moderatly built ls/vtec setup. Sorry if you feel this is a pointless thread, im just excited
yea...whats the complete setup...pistons, rods, any head work(port or vj), etc...
and can't believe it that you been driving on it for 2 1/2 years now and still making good numbers...good ****...
I didn't believe it when I saw it either. Other mods include CTR Pistons and rods, ITR Crank, springs retainers. After all I'd heard about most LSVTEC setups giving out after 20,000 miles I can't say I believe them...still runs strong as hell, if not stronger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxxxrc from 10-3-06 »</TD></TR><TR><TD CLASS="quote">
Mods: b18a1 block
b18c5 head
portflow valvetrain
CTR pistons
CTR Rods
ITR Crankshaft
ITR Intake Mani and Throttle Body
AEM Fuel Rail
RC 370cc Injectors
Steel braided fuel line
ebay generic intake
SMS 4-2-1 Slip fit header
more but im too lazy....you get the idea...The car makes 200fwhp and 141 ft lbs tq. It's in need of a good tune however the motor has always been very powerful. Redlines at 9500k with power all the way.
Mods: b18a1 block
b18c5 head
portflow valvetrain
CTR pistons
CTR Rods
ITR Crankshaft
AEM Fuel Rail
RC 370cc Injectors
ebay generic intake
The CTR block used the same block deck height as the LS/GSR/ITR blocks. But it used the same stroke length as the B16. To make up for the taller block with the shorter stroke, the rod length was increased. If you put a longer stroke in one of those blocks with CTR length rods, the pistons will pop out of the bore a good amount. A good amount as in un-useable.
No CTR rods. I will admit I was uneducated about this, but now that I know I can't make that mistake anymore (my own stupidity). Im assuming it's just the stock 90-93 ls rods, that way there wouldn't be a bore clearing issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations »</TD></TR><TR><TD CLASS="quote">who ever put that engine together did a good job</TD></TR></TABLE>
Why? Because with pretty high compression and big cams it made just over 200whp?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">
Why? Because with pretty high compression and big cams it made just over 200whp?</TD></TR></TABLE>
No because it still running. Wouldnt the ITR crank drop his compression nearly a point.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxxxrc »</TD></TR><TR><TD CLASS="quote">I bet your car is boosted.</TD></TR></TABLE>
Try betting my car is stock. Odds would be more in your favor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc »</TD></TR><TR><TD CLASS="quote">
No because it still running. Wouldnt the ITR crank drop his compression nearly a point. </TD></TR></TABLE>
That would be more dictated by the rods he used as well as the type of pistons. Its not a miracle to get an LS/Vtec to last 100k or so miles. There is no logical reason why it would die within 20k miles. Thats just from the majority of people half assing the builds.
That would be more dictated by the rods he used as well as the type of pistons. Its not a miracle to get an LS/Vtec to last 100k or so miles. There is no logical reason why it would die within 20k miles. Thats just from the majority of people half assing the builds.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_slow420 »</TD></TR><TR><TD CLASS="quote">
you are correct captain obvious. i bought the car when I was pretty naive, i made good money for a high schooler...so i bought a fast crx, not knowing completely what i was getting myself into. im glad now tho
</TD></TR></TABLE>you are correct captain obvious. i bought the car when I was pretty naive, i made good money for a high schooler...so i bought a fast crx, not knowing completely what i was getting myself into. im glad now tho
