need help plzz bout b16a2 crankshaft n b18c1 block
Old Mar 15, 2007 | 10:10 AM
fly_high_gsr's Avatar
Default need help
hey jus wonderin if i cud use b16a2 crankshaft in my 94 gsr block with no problem ?
n also i wanted to kno if 94-01 all gsr crankshafts are all same as type r ?
if not wat is the stroke on type r crankshafts ? thanks guys appreciate it
Modified by fly_high_gsr at 12:38 PM 3/15/2007
Modified by fly_high_gsr at 12:40 PM 3/15/2007
Old Mar 15, 2007 | 10:11 AM
DonF's Avatar
Default Re: need help plzz bout b16a2 crankshaft n b18c1 block (fly_high_gsr)
Simple answer, NO.
Old Mar 15, 2007 | 10:21 AM
Default Re: need help plzz bout b16a2 crankshaft n b18c1 block (DonF)
n y is dat? can u b little more clear on dat? wat i heard was i can use b16a2 crankshaft with gsr rods n b16pistons but i wanted 2 make sure
Old Mar 15, 2007 | 10:43 AM
dbiker207's Avatar
b16 crank has a shorter stroke than the b18c1
Old Mar 15, 2007 | 11:06 AM
Default Re: need help plzz bout b16a2 crankshaft n b18c1 block (dbiker207)
oh thanks so how bout if i use gsr crank with gsr rods with b16 pistons pr3 ?
Old Mar 15, 2007 | 11:10 AM
IntegraType-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fly_high_gsr &raquo;</TD></TR><TR><TD CLASS="quote">oh thanks so how bout if i use gsr crank with gsr rods with b16 pistons pr3 ?</TD></TR></TABLE>
if you used a b16 crank in a b18c block, you'd be destroking the motor..
you can use pr3 pistons on gsr rods, which will give a tad bit more compression. ..Also speak correct english please..its hard to read what your writing.
Old Mar 15, 2007 | 12:55 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fly_high_gsr &raquo;</TD></TR><TR><TD CLASS="quote">n y is dat? can u b little more clear on dat? wat i heard was i can use b16a2 crankshaft with gsr rods n b16pistons but i wanted 2 make sure</TD></TR></TABLE> Because it bee's like dat.
Old Mar 15, 2007 | 01:02 PM
tony1's Avatar
dam cuz
Rocket's Avatar
Do you want to run 0.090" side clearance on your B18C rods on the B16 crank, I wouldn't.
That's fo Shizzle!! peaCE oUT. Westsayeeed!!! Popzoa!! Booyaka!!!
Blazin the most hip hop hits in Los Angeles. Big Boiiiiii!!!! in da mornin.
Power 105.9FM
Old Mar 15, 2007 | 01:19 PM
alterdcreations's Avatar
Default Re: need help plzz bout b16a2 crankshaft n b18c1 block (Don Lackey)
use ctr rods with a b16 crank in a gsr/ls block
make sure you rev the **** out of that engine
Old Mar 15, 2007 | 01:32 PM
DonF's Avatar
Default Re: need help plzz bout b16a2 crankshaft n b18c1 block (alterdcreations)
Actually you need a B-16B crank also, some thing about side-rod clearance yO. But it bee's good yO.
Old Mar 15, 2007 | 01:34 PM
00Red_SiR's Avatar
All Motor Mentor
This thread is seriously cracking me up.....haha
Old Mar 15, 2007 | 01:35 PM
downeyballz's Avatar
Default Re: need help (fly_high_gsr)
the rods have to match the crankshaft. (gsr crank = gsr rods) the pistons are interchangable because they have the same wrist pin location, therefor they have no difrence in stroke
Old Mar 15, 2007 | 01:50 PM
Default Re: need help (downeyballz)
danm homie
Old Mar 15, 2007 | 10:29 PM
b16nonoy's Avatar
you would be making your b18..downgraded to like a b17..lol...suppose to be the other way around..but it will fit...you can use the b16 pistons also....all b-series motors are 81mm in size for pistons...except b20's they are 84mm I think...
stay with your stick GSR crank
but I could be wrong in everything I said..
Old Mar 15, 2007 | 11:36 PM
Aquafina's Avatar
foshizzle my nizzle?
Old Mar 15, 2007 | 11:51 PM
slofu's Avatar
Default Re: need help (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">danm homie </TD></TR></TABLE>
'...my mind is playin' tricks on me.'
FTW: http://www.youtube.com/watch?v=lIIsOdTc2RQ&NR
Old Mar 16, 2007 | 06:23 AM
Default Re: need help (slofu)
hahahahahahahahahaahha
Old Mar 16, 2007 | 10:30 AM
well thanks fo ya 'll helping me out even though pple think its funny i was jst wondering i dont think it hurt 2 ask rite ? well ya imma stick with gsr crank n gsr rods n just use pr3 pistons with r cams on my gsr head thanks i jst dont wan mess it up when i build it dats all ne ways u guys r big help peace
ctonytone4143
Sep 14, 2008 10:33 PM
yimmy
Oct 28, 2003 10:48 AM
Irishweird00
11
Jun 5, 2003 06:51 PM
prjctCIVIC
Oct 10, 2002 02:04 PM
sean
Sep 24, 2002 11:31 AM
