how much of a performance increase would i notice with a sknuk2 coilover kit in handling?
Old Mar 15, 2007 | 07:55 AM
spaceman00's Avatar
Default how much of a performance increase would i notice with a sknuk2 coilover kit in handling?
I have a 1996 honda civic 2dr coupe dx and im wondering how much of a performance increase id notice with a skunk2 coilover kit with LCAs when it comes to handling. Is it noticable....or would i need to get a good sway bar like the ITR to notice something?
Old Mar 15, 2007 | 08:32 AM
ke98248's Avatar
Default Re: how much of a performance increase would i notice with a sknuk2 coilover kit in handling? (space
I have gotten megan racing front & rear upper struts, Id also recommend getting the lower front and rear struts, they actually help a lot. The tread and quality of your tires also has a great deal to do with the traction you get out on the road.
I have skunk2 with stock LCA's... LCA's are mostly 4 visual, not performance, unless you pop in a sway bar. It depends how much you drop your car, if you get it aligned properly (camber, toe,etc..) you will definitely notice quite a bit better handling..
are you talking about just the coilovers, or the lowering springs, or the full suspension setup? (I'm assuming the adjustable coilovers, which is what i have.)
Old Mar 15, 2007 | 08:36 AM
spaceman00's Avatar
Im talking about going from a stock 1996 civic dx 2dr coupe to these:
http://www.skunk2.com/Merchant...de=FC
and
http://www.skunk2.com/Merchant...unt=2
Old Mar 15, 2007 | 08:38 AM
kaiba's Avatar
I'll say. It depends on how you drive it.
Old Mar 15, 2007 | 08:45 AM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Correct. I know a kid with stock shocks/springs, and he whoops most of the cars here with there heavy modded cars. He also have a single-cam . I didn't mention he does circuit.
Old Mar 15, 2007 | 08:58 AM
96hb's Avatar
It should make a big difference going from stock to that. Might wanna pair them up with some good shocks to get the full benefit. I know when I went from stock to GC's and AGX's that my car handled alot better. The ride will be a good bit different (stiff) than you are used to. It took me awhile to get used to that with coilovers.
Old Mar 15, 2007 | 09:04 AM
ke98248's Avatar
Oh, OK. Don't buy from skunk2, they rip you in the ***.. Go to google and look up: JDM IN STOCK, thats the name of an ebay company that sells really cheap and authenic skunk2 parts for at least 30% off MSRP.
Good times!~
mbish23
Suspension & Brakes
Nov 28, 2010 06:58 PM
solfire
Mar 27, 2009 08:50 PM
b20vcrxsir
Suspension & Brakes
Mar 5, 2009 08:20 AM
GEOz2k7
Suspension & Brakes
Aug 1, 2008 06:57 AM
