B16a knocking
Old Mar 14, 2007 | 09:42 PM
94HONDAHEAD's Avatar
Default B16a knocking
I got a slit rod knock on my B16a I will be replacing the rod bearings will that resolve the problem. Or will there be anything else wrong.
Old Mar 14, 2007 | 09:50 PM
2wheelhunter's Avatar
Default Re: B16a knocking (94HONDAHEAD)
well are you sure its the rod?... rod knocks usually arent "slite" try getting your valves adjusted... or take it to a mechanic... well if it is a rod bearing you wouldnt be able to
Old Mar 15, 2007 | 10:56 PM
Well its coming from the bottom of the engine and I had my valves adjusted the mechanic said that changing the bearings probably would fix it just wanted an opinion if anybody was in the same situation ever.
Old Mar 16, 2007 | 12:50 AM
Formula's Avatar
Default Re: (94HONDAHEAD)
Hate to hear that kind of news dude.
You can try replacing the bearings but if your bottom end is knocking then you might as well rebuild the entire bottom end with fresh guts.
Old Mar 16, 2007 | 02:08 AM
JDM_Frijoles's Avatar
Default Re: (Formula94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Formula94 &raquo;</TD></TR><TR><TD CLASS="quote">Hate to hear that kind of news dude.
You can try replacing the bearings but if your bottom end is knocking then you might as well rebuild the entire bottom end with fresh guts. </TD></TR></TABLE> X2
Jcup315
Sep 21, 2006 01:47 PM
projectTeG
20
May 13, 2006 01:28 PM
mattb16a1civic
Nov 2, 2003 07:20 AM
phattycrx90
Mar 9, 2003 07:52 PM
