clutch master cylinder
I replaced the clutch master cylinder line on my em1 after it was damaged. I purchased the line with a clutch master cylinder and slave cylinder, but I just used the line with the slave cylinder. Anyway, now my pedal is all the way down to the floor. Me and a friend tried to bleed the salve cylinder after pumping the clutch pedal but nothing comes out. The bottle is still holding fluid but it doesn't want to bleed.
-Any idea whats wrong? I assume the CM is still good since it's still holding fluid but it doesnt want to bleed. The lines look good too, I also checked inside over the clutch pedal and doesnt look like it leaked.
You should be glad nobody has replied to your post, because so far, no-one has been able to properly diagnose or tell you what to do because they don't know.. Believe me, you don't want everyone's opinion, only those who are qualified to answer. Be patient.
You should have an answer by tomorrow morning, just give it time.
I'm going to open detach the slave cylinder and see if the fluid leaks out, if it does I would assume the slave is bad, but if it doesnt I think the lines or CMC is bad and if thats not the case im going to set the car on fire and take pics for everyones enjoyment, no but seriously what could it be?
