Civic Overheating...Electric Fan? help ....? thanks...
Old Mar 14, 2007 | 05:49 PM
FastAssCars's Avatar
Default Civic Overheating...Electric Fan? help ....? thanks...
I have a 98 civic with a sohc vtec... anyways ... its been overheating ... the electric fan isnt coming on soon enough... what do I need to do, to fix that? please include details... thanks a lot ~ Jon
Old Mar 14, 2007 | 06:01 PM
deadline's Avatar
is it taking to long to come on ?
Old Mar 14, 2007 | 06:02 PM
Yes it is ... it comes on when its too hot already... thanks...
Old Mar 14, 2007 | 06:31 PM
anyone...?
Old Mar 14, 2007 | 07:20 PM
RiceKillinSI's Avatar
Default Re: (FastAssCars)
IMO it could be two things.
1. Your coolant temperature sensor is bad. It could be making you temp gauge say you are running hot when in reality you are not.
2. Your cooling fan switch is bad. It is the sensor that tells the fan that it is time to cut on. It should be on the engine block somewhere. I am not familiar with the SOHC engines so I couldn't tell you exactly where.
Good luck!
Old Mar 14, 2007 | 07:35 PM
thanks a lot Ill check it out...
Old Mar 15, 2007 | 06:34 PM
Where is the coolant temp sensor located? and also where is the electric fan switch? thanks a lot ... please respond my cars overheating!!!
Old Mar 15, 2007 | 07:09 PM
cars817's Avatar
you need to bleed it first and then if the problem continued change the sensor. to bleed it follow the upper radiator hose on the side you will see a nut with a little hole in the center that is where you bleed it use a 10 mm and for the fan sensor follow the lower radiator hose to the eng. @ the end you will see a big brown nut 17mm with a plug that is your sensor, and if replace do the thermostat so you dont have to deal with it later
Old Mar 15, 2007 | 07:15 PM
93eg2james's Avatar
Default Re: (cars817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cars817 &raquo;</TD></TR><TR><TD CLASS="quote">you need to bleed it first and then if the problem continued change the sensor. to bleed it follow the upper radiator hose on the side you will see a nut with a little hole in the center that is where you bleed it use a 10 mm and for the fan sensor follow the lower radiator hose to the eng. @ the end you will see a big brown nut 17mm with a plug that is your sensor, and if replace do the thermostat so you dont have to deal with it later </TD></TR></TABLE>
Awesome advice for a noob, but a little off.
Obd2 Hondas did not come with the little bleeding nipple, so to bleed the system, you have to take the rad cap off, and let the car idle for a while. As it heats up you will see bubbles coming out of the rad neck. Let it do this for about 20 min, then replace the cap. I've delt with this porblem sooo many times, and I doubt any sensors are bad. Bleed it, then let us know if you're still haveing troubles.
Old Mar 15, 2007 | 07:29 PM
Does your car cool off if you get on a highway?
Old Mar 15, 2007 | 07:31 PM
ya it does... its just like I live in Hollywood so theres a lot of stop n go traffic...so i dunno will bleedin help it from overheating or what...?
Old Mar 15, 2007 | 07:38 PM
If you have a low coolant level and air pockets in your system it is possible that topping off your coolant and bleeding your system like 93eg2james said could fix your problem.
These might be some dumb questions. Have you checked for any leaks? Have you checked your coolant level?
Old Mar 15, 2007 | 07:43 PM
umm theres no coolant leaks and the coolant level is full... so i dunno... i thought it was the fan but I dunno...
Old Mar 15, 2007 | 07:50 PM
Check out this web site:
http://autorepair.about.com/li...h.htm
It is talking about a 94 LX civic but it might help you out. It will tell you the basics on how to trouble shoot your fan. It has some pics as well. I hope this helps. Keep us up to date.
*edit* you might want to go to your local parts store to get a repair manual for your car before you try any wireing of the fan motor just in case Honda changed anything between 94 and 98.
Modified by RiceKillinSI at 9:00 PM 3/15/2007
Old Mar 15, 2007 | 08:22 PM
alrite thanks a lot ill check it out... Ill keep you guys updated ... thanks again...
Old Mar 19, 2007 | 05:33 PM
Alrite I bled the radiator.. we'll see what happens now... Ill let you guys know... thanks
SAMCRO08
Jun 6, 2013 05:39 PM
97civicdx
Jul 20, 2010 05:04 AM
xpdude
Nov 5, 2009 05:39 PM
Rayz_Si
13
Feb 27, 2008 08:29 PM
tianporn
15
Feb 20, 2005 10:56 AM
