right oil restrictor for Garrett Blowzilla turbo?
Old Mar 14, 2007 | 05:35 PM
integra3586's Avatar
Default right oil restrictor for Garrett Blowzilla turbo?
i have this with the .63 exhaust side.
and i bought this oil restrictor, is this the right one?? im asking because on extreme psi it says its a 7/16 thread pitch. when i go to ACE. its the same thread pitch as a 1/4 compression fitting. BUT on ATPTURBO.COM there restrictor says its a 1/8" NPT and it fits all T-Series Turbos. and now i have someone saying it could be a 10mm-1.0 fitting. i dont want to take apart my oil line only to find out i have the wrong one in there. its a ramhorn mani, so its a bitch to change
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett T3/GT40 "BLOWZILLA &raquo;</TD></TR><TR><TD CLASS="quote">
Product Description
compressor: GT40
.70 a/r
61mm inducer
flow: 65 lbs/min 832cfm
turbine: T3
your choice of .63a/r or .82a/r housing
stg3 turbine wheel standard
360* thrust bearing standard
*same compressor section as GT35R
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extreme psi oil restrictor &raquo;</TD></TR><TR><TD CLASS="quote">
PTE turbo oil restrictor fittings.
Fits most Garrett/PTE Turbochargers
Please select size fitting below.
Old Mar 14, 2007 | 07:37 PM
Default Re: right oil restrictor for Garrett Blowzilla turbo? (integra3586)
bump
Old Mar 14, 2007 | 08:23 PM
73 views and no one knows?
Old Mar 15, 2007 | 08:30 PM
Old Mar 16, 2007 | 05:58 AM
rudebwoy's Avatar
thats H-T for you. throw in GT BB, F R or M@#E the description it will get replies,
the threads of the turbo oil feed is 1/8 npt. now the rest depends on what size line you are running 3AN or 4AN.
Old Mar 16, 2007 | 05:12 PM
Default Re: right oil restrictor for Garrett Blowzilla turbo? (rudebwoy)
thanks man, i appreciate that
Old Mar 16, 2007 | 09:43 PM
Brian@FP's Avatar
If that thing is conventional Journal bearing as the "360 thrust bearing" description would have you believe, then I wouldn't run any restrictor unless you peg oil pressure gauges out above idle.
90lsvcrxva
Jul 15, 2008 03:12 PM
sleepencivic
Jun 6, 2008 06:55 PM
94civic18
Nov 26, 2007 08:58 AM
hbyrd8701
Feb 12, 2007 07:38 AM
ongking
Nov 9, 2006 04:52 PM
