Key/Ignition barrel swap question
Old Mar 14, 2007 | 04:38 PM
DmcL's Avatar
Default Key/Ignition barrel swap question
ok so assuming all goes well and i pick up this donor ef...
i will be swapping both doors and locks over to mine. can i also just swap over the ignition/key barrel into mine since mines fubar and just use the keys from the donor car? i dont see why not but i figure its better to ask first.
also is there any real difference between a non power steering rack/column and a power steering rack/column? i dont want to install PS into mine, wanna keep it non PS. is there less/more turns lock to lock on one rack than the other? with any luck i wont need to swap columns/racks. mine doesnt seem too bad but theres a slight resistance at a certain point. only a little tho so could maybe un-bend it?
Old Mar 14, 2007 | 04:43 PM
rbwdriven's Avatar
The ignition key swap is pretty easy.
Only issue is to drill out the magic little bolts that attach the key barrel to the steering shaft.
Regarding the column they are both the same. unless one is a tilt column and the other is not. Then there is a difference.
Old Mar 15, 2007 | 03:27 PM
DmcL's Avatar
mines a tilt column. dunno about the other one as i havent seen it.
they managed to pop 3 big fuses under the hood. possibly some smaller ones too. they popped all 3 big fuses, a 40, 50 and 60 amp.
89LSED
Sep 11, 2010 11:49 AM
BrayzieEF9
May 4, 2010 07:30 PM
truevietluv636
Oct 10, 2006 03:56 PM
too much vtAK
Aug 31, 2006 07:55 AM
