Need to know how to fix
Old Mar 14, 2007 | 03:04 PM
Under Con. CrX's Avatar
Default Need to know how to fix
how do you fix or where do you fined your *intake air temperature sensor* my ECU is throwing that code and i dont know where its at or how to locate it and how to fix it how do i locate and fix???
all coments welcome
Old Mar 14, 2007 | 03:12 PM
Default Re: Need to know how to fix (Under Con. CrX)
Old Mar 14, 2007 | 03:30 PM
viciousef9's Avatar
dont fix just up grade to a peformance intake and dont worry about it.
Old Mar 14, 2007 | 03:34 PM
Slurp56's Avatar
Upgrading your intake will not solve your problem. The IAT sensor is typically located in your rubber intake arm near the throttle body, or in 1 of the intake runners (usually cylinder 1) and is typically a white connector.
Old Mar 14, 2007 | 03:36 PM
janz3n's Avatar
Default Re: Need to know how to fix (viciousef9)
its on the intake manifold on the drivers side. its got two screws holding it in. search it on here and your probably get pictures. be carefull not to strip the screws. iv never replaced one but iv tried taking one off of a dpfi manifold and i stripped the screws to ****. but its pretty simple to replace. good luck.
Old Mar 14, 2007 | 03:38 PM
Default Re: Need to know how to fix (janz3n)
thanks i am going to take a look at it
one more Q would that prevent my car from starting??
Old Mar 14, 2007 | 03:41 PM
janz3n's Avatar
i would say no. dont see why it would.
Old Mar 14, 2007 | 03:54 PM
ok thanks any way
ohh and what the best way to get a striped screw out turns out the the one on my IM all ready had it striped so i am trying to figure out how to get it out
Old Mar 14, 2007 | 04:19 PM
janz3n's Avatar
alot of cursing , hack saw and vise grips.. i wouldnt want to be you right now lol.. good luck.
Old Mar 14, 2007 | 04:26 PM
Slurp56's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks any way
ohh and what the best way to get a striped screw out turns out the the one on my IM all ready had it striped so i am trying to figure out how to get it out</TD></TR></TABLE>
Drill the head off, remove the sensor, then use your fingers or vice grips to spin the stud out.
Old Mar 14, 2007 | 05:09 PM
Default Re: Need to know how to fix (Slurp56)
ok thanks will do
CKnight90
Sep 23, 2013 04:31 PM
bobss
Apr 3, 2007 06:20 PM
migizzel
Dec 6, 2005 08:24 PM
DragInteg
May 4, 2004 09:15 AM
vultron
Dec 13, 2003 09:45 PM
